Let's talk about catch cans
Old Aug 27, 2018 | 12:22 PM
bigdhenderson's Avatar
Default Let's talk about catch cans
Anyone have one (or two) oil catch cans installed? The 5.0 guys like myself could benefit from having them. Im currently working on my own, but I'd love to see some pictures of anyone else who has them.
I'll also post up my progress along the way. Looks to be a fairly straightforward project and in my opinion very worthwhile to have.. I will also be doing this to my f150 ecoboost.
Old Aug 27, 2018 | 12:59 PM
Cee Jay's Avatar
I've had them on other vehicles, but haven't put one on the Jag (yet). Now you may have gotten me motivated....
Old Aug 27, 2018 | 01:14 PM
I was always under the impression that the factory pcv and oil separators were enough, until I had the great pleasure of ripping off my blower and seeing inside the intake ports and manifolds.
Old Aug 27, 2018 | 08:29 PM
Sean W's Avatar
A few guys on the X350 forum have put them on but of course those are the 4.2 liter.....
https://www.jaguarforums.com/forum/x...lastic-205829/
Old Sep 5, 2018 | 03:51 PM
It is proving difficult for me to pick a proper catch can...what I want doesn't seem to exist
Old Sep 5, 2018 | 04:14 PM
Cee Jay's Avatar
Fill in the specs you want, if it's made it will be there:
Choose a Catch Can at Summit!
Old Sep 6, 2018 | 09:13 AM
Thanks, but no luck there either. I'd like a square/rectangular tank with mounting tabs, a good baffle design, 19mm inlet and outlet, and a cap on top. I may just end up having to settle for something else or try to find the time to build one.
Old Sep 6, 2018 | 10:38 AM
Rey's Avatar
Rey
I'm wondering just why a catch can is needed? Jaguars are quite "oil tight", meaning there is not a lot of blow-by past the rings. So, what's to catch?
I had a '12 Hyundai Genesis 5.0, which used about a qt/2000 miles. Oil vapor was routed to intake manifold, much like many cars. I removed the throttle body and extracted about a cup of oil from bottom of intake manifold. Installed a catch can, which caught and condensed the oil vapor.
Contrasted with Jaguar: I have a '07XK with 42K miles and '13 with 10K miles. I have checked, over time, the interior of intake manifolds - both are "dry".
Old Sep 6, 2018 | 10:57 AM
If you plan on driving that '13, put a catch can on now. I've seen what the intake valves look like at 75k miles. Wish I would've done one when I first got the car at 50k miles...
Even a tiny bit of blow by over the course of many thousands of miles will add up on the intake valves. I think you are spot on with the Jag engines being "tighter" , which is probably why they have far less issues with carbon buildup as compared to BMW and Audi.
Old Sep 6, 2018 | 11:41 AM
Cee Jay's Avatar
Well then... Someone needs to install a catch can then drive around for a few thousand miles; drain it and let us all know the caught quantity.
Old Sep 6, 2018 | 12:23 PM
shemp's Avatar
Looks like that's gonna be Mr. bigdhenderson ??
There are a ton out there. Why so picky This one has custom mounting and different inlet sizes a dip stick!
Amazon Amazon
Old Sep 6, 2018 | 12:31 PM
The inlet and outlet size aren't big enough, needs to be 19mm (3/4"). I don't want to reduce size of the factory piping. I've ordered a couple (doing a dual can setup) for BMW n54, as they have true 19mm inlet and outlet, but they don't have a lid. I would rather use the vacuum extractor to suck it out during oil changes rather than having to unscrew the bottom of the canister, but they will have to work for now.
Old Sep 6, 2018 | 12:33 PM
shemp's Avatar
ah, got it.
Old Sep 6, 2018 | 01:04 PM
Cee Jay's Avatar
Maybe make one? They are really very simple things.
Old Sep 6, 2018 | 02:57 PM
Ranchero50's Avatar
They are not simple when it gets cold out. Ran into problems on the Sportster where the moisture in the oil mist turned the whole thing into a smelly brown mess. Summertime was OK though...
Old Sep 6, 2018 | 04:42 PM
Anyone know if the full load breather tube needs to be hooked up to the intake? Is this something that could be deleted from being tied-in to the intake tube and just ran through a breathered catch can?
Old Sep 7, 2018 | 08:37 PM
Catch cans mounted
Old Sep 8, 2018 | 12:28 AM
Cee Jay's Avatar
Covered by the corner trims when installed?
Now just to Hook 'em Up!
What kind did you end up getting? Can't tell from picture.
Old Sep 8, 2018 | 10:41 AM
Yep it'll be an incognito install...ended up getting 2 off amazon, made my own mounts. No drilling required, completely reversible with no trace.
Old Sep 9, 2018 | 01:51 PM
JackJohn's Avatar
Catch cans mounted
No CJ, they are the white ones standing over by the wall.
