Lock/Unlock chime
Old Apr 22, 2010 | 02:53 AM
sorapp's Avatar
Default Lock/Unlock chime
Does anyone know if it is possible to program the locking system so it sounds a beep/chirp when enabled or disabled? My '05 XK8 had this but my '07 XK does not. I miss the audible reminder, I find that I must actually look at the lights to make sure it locks.
Old May 11, 2010 | 10:16 PM
davies's Avatar
Default Kevin
Don't hold me to this but I believe that the no noise on lock and unlock is regulated to remove noise pollution. I believe that all late model cars are the same and as such there is no adjustment to turn on or off.
Old May 11, 2010 | 10:53 PM
GhostriderXKR08's Avatar
With the Key Fob I find you'll need to press the lock button twice in a row for the horn to beep.....don't think you can have it chime when you unlock it though.
Old May 12, 2010 | 02:17 PM
sorapp's Avatar
I tried the double click as you suggested, the lights just flashed a second time, no audible feed-back.
Has anyone noticed in the owners manual, page 7, they reference pressing the lock button on the remote a second time to "double lock" the car. What does that mean?
Old May 12, 2010 | 05:48 PM
That's strange......your horn should beep like this after pressing the lock button twice:
http://s818.photobucket.com/albums/z...t=MOV03618.flv
Might want the dealer to check it out.
Old May 12, 2010 | 09:35 PM
Brutal's Avatar
double locking is not avail in the US. And I believe the sounder can be abled/disabled, but not through the touch screen. Its probobly in IDS to enable chirp. We used to have to FIX Stypes for this all the time. They would quit and we would have to go in and disable, then reenable to get it functioning again.....(computers, all just a bunch of pooey for enriching our lives)
Old May 14, 2010 | 09:42 AM
stevef's Avatar
I know what you mean about the audible reminder when locking the car,
I also miss it, comes from growing up in NYC you get a little paranoid about making sure your car is really locked.
I don't know if the 07 has this feature, but what I have done is go into the settings and activate the mirror fold feature upon locking. This way when you lock and start to walk away you know its locked if the mirrors are folded.
Old May 14, 2010 | 04:06 PM
sorapp's Avatar
That's a great alternative to the audible, unfortunately my '07 does not have this feature. I also am originally from NYC, nice to know I'm not the only one with this paranoia.
Another member on this forum has an '08, and he can get the beep with a double push of the lock button on the remote. My dealer insists this can't be done on the '07. Still looking for alternative.
Old May 14, 2010 | 10:38 PM
ShadyJC's Avatar
I have an 07 and mine will sound the horn once if I double push the lock on the remote.
Old Nov 7, 2010 | 12:13 AM
sorapp's Avatar
Was your '07 built for sale in the US? My dealer says some features vary by market.
Old Nov 7, 2010 | 02:31 PM
davies's Avatar
The double lock feature causes the doors to lock both inside and outside... That is once you ave double locked the car you cannot open the door from the inside either. If someone breaks a window to gain access to the car, if you have double locked the doors they will be unable to open the doors even from the inside. Kevin.
Old Nov 13, 2010 | 10:00 PM
sorapp's Avatar
Default Problem solved!
After repeatedly complaining to dealer about this issue the tech discovered that the warning audio system used to created the sound via a speaker ( it does not use the horn) was not operating. This system also is used to produce a warning if you try to lock the car with a door open, which does not work either. Taking car in next week to have audio warning system repaired.
UPDATE!
The sounder was replaced and now I get the chirp when I double click the lock button. It also chirps if you double click the black button on the door handle. Dealer says this feature can be enable/disabled via an IDS update. He charges a 1 hour labor fee to make IDS changes. At last I am happy.
Old Nov 14, 2010 | 08:14 PM
jaglover922's Avatar
The dealership can do it possibly by either reconfiguring the CJB(Central Junction Box) or disable and enabling it through the car configuration file with IDS/SDD
Old Dec 7, 2010 | 07:33 AM
WldCat's Avatar
UPDATE!
What a PITA! Good for you for keeping after the dealer to investigate/resolve the problem. (Squeaky wheel and all that.)
Doug
Feb 27, 2019 01:31 AM
John Fox
Jan 1, 2016 09:13 PM
hoodun
Oct 2, 2015 10:13 PM
XJ8JR
Sep 2, 2015 02:38 PM
