New Oil choices for 5.0
Old Jul 26, 2018 | 12:51 PM
Queen and Country's Avatar
Default New Oil choices for 5.0
What do you guys think about 4 new choices for oil now available in USA.
They all meet the current Jaguar spec for 5.0 engine
1.https://www.racecompusa.com/product/...ne-oil-107339/
2.https://www.ebay.com/itm/JLR-51-5122...4383.l4275.c10
3.https://www.ebay.com/itm/RAVENOL-0W-...L/371451382462
4.https://www.ebay.com/itm/NEW-BMW-Jag...n/361995063214
Thoughts, advise, warnings, ridicule, all welcome.
Castrol has become harder to find.
Old Jul 26, 2018 | 02:42 PM
sparky fuze's Avatar
Oh's Nooooooooooes! Not this again.
Old Jul 26, 2018 | 02:55 PM
Sean W's Avatar
No dog in this fight. Just here for the entertainment.
Old Jul 26, 2018 | 03:32 PM
For Fuch's sakes guys.
Did not even bring up Fuchs Motor Oil which was the 5th choice as I knew the group would snicker.
https://www.ebay.com/itm/Fuchs-TITAN...2/292644919559
Have my eye on Jacco
Cant find Castrol- this is serious
Old Jul 26, 2018 | 05:25 PM
Don-T's Avatar
Pretty pricey stuff! I can get the Castrol Pro 0-20 at my dealer for under $8 a quart.
Old Jul 26, 2018 | 06:21 PM
pwpacp's Avatar
I'm glad to see there are other possibilities available. I'm on a road trip at the moment and will visit a Jag dealer in Memphis to pick up a Castrol supply. I'll be looking to see comments about one of these as a possibility in any case though. Just changed oil the other day so I've got tons of time to read what the group comes up with.
Old Jul 26, 2018 | 09:16 PM
TXFireblade's Avatar
Pennzoil Ultra Platinum 5W-20 meets the spec for the cars that require this grade and it can be bought on-line from Walmart for $25 for 5 quarts.
Old Jul 27, 2018 | 02:17 AM
I wish I could, and I am 5 mins from the dealer, but they want $12.88. No way to change oil every 9months at those prices and not feel taken.
$8 is a fantastic price or any POA based oil.
Old Jul 27, 2018 | 07:49 AM
TexasTraveler's Avatar
Looks like a lot of Home Depot stores stocks this as well...
Old Jul 27, 2018 | 09:51 AM
One thing reassuring is that all 5 companies making this formulation, are all charging about the same price. So this must be expensive to produce.
But I dont care about the money, its the availability.
Old Jul 27, 2018 | 09:58 AM
shemp's Avatar
I am reading 2015 and UP 5.0L engines for compatibility on these oils. Does this new spec apply to our 5.0Ls? ?
Sorry, too busy to do the research on my own right now but if you already know, please share
Old Jul 27, 2018 | 10:05 AM
Shemp,
Yes they silently went to it.
https://topix.jaguar.jlrext.com/topi...50a34ec&page=1
(I agree that it was a step in the right direction, there was an issue of oil not flowing fast enough to the chain tensioner on startup)
Old Jul 27, 2018 | 12:15 PM
Stuart S's Avatar
If both (0W-20 and 5W-20) meet JLR lubrication specs, why spend more for the 0W-20? I doubt that the incrementally better fuel economy of the 0W-20 is worth the cost.
Old Jul 27, 2018 | 12:23 PM
BlueXKR-S's Avatar
Probably depends more on the min temperature your car sees. I never start my engine when it's bellow freezing, so 5W is probably fine for my case
Old Jul 27, 2018 | 12:24 PM
No they are the same money, the older spec is the one harder to find and most likely old stock.
Old Jul 27, 2018 | 12:32 PM
They went to the thinner oil due to soot loading.
I.e. it becomes same as 10w-20 after a while- which was causing complaints
You want the 0w in an XKRS that does not see winters- only so as to keep up with Jags latest advancements. (there are other things updated besides the viscosity)
Old Jul 27, 2018 | 05:35 PM
10XKR's Avatar
I agree, and also what keeps the gears going inside my head is that part of the reason I have seen touted for the "0" is due to the tight tolerances of the 5.0...so what about as these engines age and wear with higher mileage. Wouldn't a 0 weight be detrimental vs a 5 weight with higher mileage above say 75K miles?
Just thinking out loud.
Dave
Old Jul 27, 2018 | 06:08 PM
Cee Jay's Avatar
Dave
Use half 0W and half 5W.
Old Jul 27, 2018 | 06:09 PM
jagtoes's Avatar
Dave
I am watching mine now to see if there was any affect in going from 5W-20 to 0W-20. My 2012 XKR has always been dealer services either by the 1st owner or myself. Up until April of this year my service slip from the dealer listed 5W-20 . This year when I asked the dealer they said the TSB required them to go to 0W-20 with the 5.0L engine. So I have put on 2000 miles since my oil change and the e-dip stick still reads full. I don't think this would be a problem but I'll keep an eye on it to see. Trust but verify
Old Jul 27, 2018 | 06:32 PM
Stuart S's Avatar
When the engine has warmed up to normal operating temperature, what difference does it make if it's filled with either 0W-20 or 5W-20? They're the same 20W viscosity when warm.
And I disagree with Q&C's conclusion that "they're both the same money". That depends on where you are. Prices vary by location.
