New xkr headlights not self leveling.
Old Apr 12, 2022 | 07:44 PM
Elhajj33's Avatar
Default New xkr headlights not self leveling.
My 07 XK has self leveling and aiming headlights. I just got two new headlamp assemblies that were installed as part of a new comprehensive insurance claim that had the front of car painted and the headlamps replaced.
the headlamps will move left and right but they do not go up and down to self level when the car starts.
I think the shop made some sort of mistake but not sure what needs to be done here.
Old Apr 12, 2022 | 09:02 PM
Stuart S's Avatar
You need to contact the insurance adjuster who handled your claim and explain why the repair is unsatisfactory and that they need to reopen your case. Be sure to follow up in writing to confirm your conversation.
Your insurance company should authorize the diagnosis of your problem by a Jaguar dealer who may be able to fix the body shop's error.
Good luck and let us know what happens.
Old Apr 13, 2022 | 07:27 AM
Elhajj33's Avatar
oh I definitely called. I’m waiting to hear back from the insurance so they can come out and inspect the car.
I read somewhere the lights need to be programmed to auto level. Is this case?
I know they are aiming left and right but they are not going up and down to level like my old lights when the car comes on
Old Apr 13, 2022 | 08:10 AM
The Workshop Manual doesn't suggest headlamp replacement requires programming. They should initialise and move to the correct position. I've attached the relevant extract.
Sounds like the leveling has set to default position due to component (or possible harness connector) failure. SDD is going to be required to find the precise cause. Armed with the description, you will know considerably more about it than the inspector from the insurers.
Old Apr 21, 2022 | 11:30 AM
Elhajj33's Avatar
quick update on this. After a day or so, I saw the self leveling procedure start to happen after the car was started. However, the right headlight still seems higher than the left. Is there a way to adjust the light? There has to be some adjustment on the self leveling/afs headlight somewhere...
Old Apr 21, 2022 | 05:44 PM
JackJohn's Avatar
Yes, both headlights can be manually adjusted Up/Dn & L/R. There are two adjusters on each light, requires an Allen wrench. Look for white plastic caps, pop them off and go to it.
Old Apr 21, 2022 | 06:39 PM
Elhajj33's Avatar
I only see one cap. Are you sure there are he’s adjustments on afs lights?
Old Apr 22, 2022 | 07:46 AM
guy's Avatar
guy
absolutely there is. I adjust mine differently for winter and summer driving.
Old Apr 22, 2022 | 07:40 PM
JackJohn's Avatar
Yes, I just went to the garage and looked at them again. the Up/Dn is on top, a little outboard of center. The L/R is also on top just inboard of the top mounting tab.
Old Jun 5, 2022 | 01:18 PM
ram_g's Avatar
@Elhajj33 did you get your issue sorted? Did anything need to be replaced?
Trying to learn as much as I can about these headlights!!
Old Jun 6, 2022 | 01:49 AM
steve_k_xk's Avatar
Please explain what settings do you have for winter and summer driving ??
Also guy is correct there is two adjustment..see pic
Old Jun 7, 2022 | 08:56 AM
guy's Avatar
guy
where I live we get SNOW and freezing rain. To reduce glare and keep the road illuminated, I slightly lower the beam for the winter.
(a trick I learned from my winter rally driving father)
Old Jun 7, 2022 | 04:25 PM
steve_k_xk's Avatar
Clever
Paul Calvert
Dec 7, 2018 07:04 PM
MaximA
May 28, 2015 07:35 PM
sts-v
Dec 30, 2013 01:55 PM
yjmcb
Mar 23, 2010 10:08 PM
lynne8090
Sep 10, 2008 07:32 PM
