No response from soft top
Old Mar 24, 2018 | 07:09 AM
AndyXKR's Avatar
Default No response from soft top
Had to replace the battery on a 2009 XKR 5.0L convertible Tried to open roof but no response from soft top is there something that need s to be reset for the top to work
Old Mar 24, 2018 | 08:44 AM
Welcome to the forum - I've moved your post from the X100 to the X150 forum based on the year of your XKR. Members here can best assist with your issue.
As this is your first post, please stop by the New Member section and post an intro - in return, you will receive a warm welcome and some useful tips for forum navigation - enjoy
https://www.jaguarforums.com/forum/n...-intro-must-5/
Old Mar 24, 2018 | 11:29 AM
jagtoes's Avatar
A couple things to check. Make sure you put the boot top cover in place correctly. Take it out and reinstall. Look t the left edge to make sure the little metal tab is still on as that's what triggers the switch. If that is OK then reset both windows using the procedure in the OM. If it still fails to open then there is a bigger problem. Others will chime in here.
Old Mar 24, 2018 | 12:32 PM
Cee Jay's Avatar
Old Mar 24, 2018 | 02:31 PM
tommytess's Avatar
Default Takes a while
When I changed my battery my finger was on the button for at least 4mins before the roof moved.
. Tommy
Old Mar 26, 2018 | 11:09 AM
110reef's Avatar
Mine makes no audible warning.
Old Mar 27, 2018 | 10:27 PM
ralphwg's Avatar
Old Apr 4, 2018 | 11:29 AM
AndyXKR's Avatar
Hi, boot separator is in place, normally if this isn't in place the windows drop but the roof doesn't retract if it's not in place. When the roof switch is depressed nothing happens at all so will need to check I didn't break any connections whilst removing the battery as it's a real pain in the X150 convertible to get the battery out.
Old Apr 4, 2018 | 11:40 AM
WhiteXKR's Avatar
It is unlikely that you broke a connection. Try removing fuse F8 (in fusebox between the rear seats) for 10 seconds and then reinsert it. Hold the button for a good minute and see if it comes back to life.
If not, you will need to follow the manual reset procedure in the owners manual.
Old Apr 4, 2018 | 04:29 PM
AndyXKR's Avatar
Ok thanks for the info, I will try that when the weather improves as it's snowing here just now and I don't want to try opening the roof as the car is kept on the drive, in case it doesn't close properly
Old Apr 4, 2018 | 05:11 PM
Woo5ie's Avatar
There are two sensors/contacts One is shown at the end of the bar that had to removed as shown above. The other is the boot/roof separator that detects whether the separator is up or down. On my 2007 the roof or window do not move if the separator is not properly in situ.
Old Jul 30, 2018 | 02:33 PM
AndyXKR's Avatar
Hi,
Just a note, to say I managed to get the soft top to work after disconnecting the Negative terminal on battery for around 15mins and reconnecting and have no problems since
Old Jul 31, 2018 | 10:11 AM
JackJohn's Avatar
Glad to hear you got it going Andy.
mberman
Mar 21, 2018 08:35 AM
sgvkirbster
Mar 3, 2018 06:05 PM
sogood
Jan 25, 2018 09:09 PM
The Black MUNK
Jan 17, 2018 12:40 PM
