Popping noise under driver seat
Sometimes when I turn right into a parking lot and go up the ramp that is at a right angle to the street to get to curb level I hear a popping noise underneath the center of the car. Kind of like the frame is contorting or something like that. The pophappens when I am in the middle of the turn (e.g., front wheels on the ramp and back wheels on street). It doesn't happen all the time. Might depend on how cold it is outside...not sure.
Any thoughts? Is this normal and is there anything down there that should be lubed to reduce/eliminate the problem?
Thx!
Thx!
Wow, I get the same sound when I pull into the parking lot at work and start backing the XK into my parking spot. For me, it is almost a "thunk" sound. Doesn't happen evey time, but happens often enough. I was fearing maybe a lose motor or transmision mount, but I just don't think so...
A unsettling mystery to be sure, but i am now somewhat reassured that my XK is not the only one...
Should this be a concern? It is the only thing about the car that doesn't make sense to me.
I had this happen to me when I had my 02 XKR. The pop happened when i would turn to the right, go over a bump, and sometimes when I would change direction.
I finally got tired of it and took my car to the guy I trust to work on my Jags - he has a lot of experience with these cars.
He went straight to the nuts on the struts. (sounds a little weird but true
) under the hood. I told him I checked those and they were tight. Well, turns out they have to be tighter (specific torque) or they will "move" which will cause the popping sound. And the sound also "sounded like" it was under my car when happened too.
He tightened the bolts first on the driver side and the popping stopped. The passenger side nuts were torqued properly...
) under the hood. I told him I checked those and they were tight. Well, turns out they have to be tighter (specific torque) or they will "move" which will cause the popping sound. And the sound also "sounded like" it was under my car when happened too.He tightened the bolts first on the driver side and the popping stopped. The passenger side nuts were torqued properly...
Thanks!
I have been wondering if anyone on this thread ever brought their XK down to the dealer for this issue and if the dealer indeed confirmed the problem was based on loose struts..
The only time I go to the dealer for anything is if that is the only place I can get the "anything" done. I'll add that in my experience my guy in Tucker, GA, has fixed things the dealer had no clue about.
For anyone that lives on the east side of Atlanta, Jaguar-Cadillac of Northlake is an outstanding place to take your Jag. They are extremely knowledgeable about Jags (and other expensive cars).
So, the pop from turning right going over a bump was related to the left shock top mounting?
Thanks, because it happens *every* time on my XJR turning hard right into a specific parking lot entrance just as the right wheel passes over the curb and onto the driveway slope.
I'll need to check the previous service record to see which side the ball joint was replaced on ... twice.
BTW, going over speed bumps where both wheels hit at the same time is no problem, cheating on speed bumps with the right wheel almost skimming the curb to stay on the flat is also not a problem.
[bold]So, the pop from turning right going over a bump was related to the left shock top mounting?[/bold]
But, 9/10 of the shock mount plate bolts and 3/4 of the mount plate bolts below them were only "firm" last night. Not falling off, and more than "snug", but definitely not as "tight" as you would expect a suspension bolt to be.
After tightening them, driving the car seems quieter today. The acid test of course is to go back to that one specific parking lot entrance and give it a go without creeping over the curb.
Then it would be time to get the wrenches out and go over every single fastener in the suspension.
Sometimes being rust free is not as good as having some rust to hold everything tight
After two tightenings, and two trips to the particular parking lot, it *seems* that the crunching is greatly reduced. But, each time there was a car in front, so the speed was kept down.
The chief passenger noted on the first tightening and before hitting the parking lot, that to her, the car seemed much quieter.
The remaining crunch/bang seems to sound exactly like other loose swaybars, so that will be checked next.
Looking at the system, the top bolts would only affect the shock mounting. But, the bottom bolts are part of the cross beam retention. This is notable because the steering *seems* a bit tighter.
There are no specs for those top bolts. But, standard industrial fastener torque charts for 8mm 8.8 rated metric fasteners call for 220 inch pounds. The fasteners for the cross beam on a X308 call for 20NM. The crossbeam on a X308 is not the same as it is stamped steel.
Sorry I've been offline for a while....got the car back from the dealer and they said they couldn't reproduce the problem in the shop. Before I dropped the dealer off for some other work, I drove in and out of every parking lot near the dealer and couldn't reproduce it myself...so I didn't expect much. They said they checked the "nuts on the struts" (as another poster called them) and they were fine.
If I can find a lot by the dealer that does it, I'll take it back in.
