Pre and Post 2010 rims difference - just validating
Old Dec 11, 2018 | 06:38 PM
mchums's Avatar
Default Pre and Post 2010 rims difference - just validating
OK, so in my efforts to swap out my wheels i'm doing some digging and just need my brain confirmed by all the experts on this.
From what I've read, in 2011 Jaguar increased the rear offest by +15mm (from 25mm to 40mm). So you could use a Pre-2011 XK/XKR rim on a +2011 XK/XKR with a spacer but you can't go the other way around, can't put a 2011+ rim on a Pre-2011? Correct??
Thanks!
Old Dec 11, 2018 | 06:44 PM
flyc2c's Avatar
If the engine is a 5.0 then it has an "e-diff". If it has the e-diff then it has the higher offset wheels. So yes, you could use the newer wheels on an older car with spacers but not the other way around.
Old Dec 11, 2018 | 06:48 PM
mchums's Avatar
yep, it's the 5.0L. Thank you!
Old Dec 11, 2018 | 10:48 PM
CleverName's Avatar
e-diff was only on the XKR, correct?
Old Dec 12, 2018 | 10:04 AM
mchums's Avatar
@CleverName seems to be right. Manual states only the supercharged cars have e-diff. So I guess I’m back to my original question.
Old Dec 12, 2018 | 01:38 PM
mchums's Avatar
i think i'm back-asswards.
Since they increased the wheel offset in 2011 by 15mm, using a spacer would essential subtract from the offset meaning a 2011 wheel would work on a 2008 XKR with a 15-20mm spacer on it. But can't go they other way around. truth??
Old Dec 12, 2018 | 02:12 PM
S-Typer's Avatar
Thats correct. The earlier wheels will stick out too far because the e-diff is longer than the standard open diff in the earlier cars.
Old Dec 12, 2018 | 02:30 PM
pwpacp's Avatar
I had a set of 20" left over from my prvious 07 XK that I tried on my 12 vert.....the fronts have the same off-set so were no problem but the rears rubbed the wheel arch quite badly.
Old Dec 12, 2018 | 02:46 PM
mchums's Avatar
right - you can only go backwards. putting the 11's on the 07.
Old Dec 14, 2018 | 01:21 AM
Brewtech's Avatar
the benefits of being the oldest of three(original, facelift1, and facelift2
Old Dec 15, 2018 | 03:01 PM
CleverName's Avatar
Dang it!
I was hoping to swap rims between my 07 XK and my 2010 XKR! If Im keeping the XK, I like the XKR rims a lot better! (plus they have new tires on them)
webshark
Apr 17, 2016 11:10 PM
X-type_Sean
Jul 12, 2015 05:30 PM
rscultho
Apr 2, 2012 09:41 AM
nickdentist
Nov 13, 2011 07:23 AM
sempaipaul
May 23, 2007 08:36 PM
