Rear 1/4 window problem
Old Mar 20, 2025 | 10:18 AM
badicedog's Avatar
Default Rear 1/4 window problem
Good morning gentlemen. 2009 Jaguar XK Convertible. Rear driver’s side window does not roll up when top is put up. I can rear the window motor doing “something” but window doesn’t roll up. Any suggestions on trouble shooting this? Anyone replaced window regulator or had similar problems? Thank you.
Old Mar 20, 2025 | 01:29 PM
Paws4thought's Avatar
Hi Badicedog, I had the same problem as you describe further investigation revealed that the cables that are driven by the window regulator motor have become detached from the pulleys.
The cables are not available from Jaguar or aftermarket but the whole regulator assembly is available but it is expensive, a far cheaper solution is to use a kit which includes the drive pulley, cables and cable seating mechanism that is meant for the XK8 convertible.
Paul
Old Mar 20, 2025 | 04:43 PM
chasr's Avatar
I was at the dealer today as I'm having the same issue with my right rear quarter window not coming up. They indicated it was the regulator.
Old Mar 20, 2025 | 06:46 PM
kj07xk's Avatar
There is also a company, in Florida I think, that will rebuild your regulator. Search this forum for ‘window regulator’, I’m sure a thread mentioning their name will pop up.
Edit: See post #4 in this thread:
Window Regulator
Old Mar 20, 2025 | 07:15 PM
chasr's Avatar
Outstanding! Thank you for linking us to this very informative thread. I will be contacting this rebuild company tomorrow.
Old Mar 21, 2025 | 02:49 AM
badicedog's Avatar
Thank you guys! Much appreciated.
Old Mar 24, 2025 | 04:47 AM
stockcar's Avatar
Unforunately this is a common problem. The wire has come off the guide rollers or the rollers themselves are damaged. It is an absolute pig to get out and back in needing a lot of disassembly of trim and components. My replacement and labour cost me nearly Ł1500 in England, half in labour and half in the part plus tax. I seem to remember there is a company in the US that rebuilds them for a good price. If I can find their details I will update you.
Old Mar 24, 2025 | 07:46 AM
fritzthecat's Avatar
Check out this link to a write-up I did a year ago:
https://www.jaguarforums.com/forum/x...-166690/page2/
Rick
stone4140
May 6, 2023 11:26 AM
2003JagStr
Nov 20, 2022 07:17 PM
adenshillito
Nov 9, 2022 08:23 AM
badicedog
Apr 25, 2022 10:53 AM
