rear quarter panel '07 xk
Old Dec 13, 2022 | 11:13 AM
restd's Avatar
Default rear quarter panel '07 xk
Has anyone else had rear quarter panel pull back? Any thoughts on repair, or do i need to replace the entire quarter panel?
thanks!
Old Dec 13, 2022 | 02:04 PM
Cee Jay's Avatar
Have an upholstery shop fix it. That will cost a LOT less than a new part, which isn't available anyway. You'd have to scour the breakers' inventory and hope to find one. I'd think it'd be best to do both sides if the color isn't spot-on the rest of the interior.
Old Dec 13, 2022 | 03:01 PM
restd's Avatar
thank you
Old Dec 13, 2022 | 06:11 PM
JackJohn's Avatar
I tried several upholstery shops, no joy. Most were up front and said they couldn't match the color, the one that said he could, couldn't. I finally found a useable panel at Pacific Motors (breaker)
Old Dec 13, 2022 | 06:13 PM
kj07xk's Avatar
Have seen them pop up on eBay occasionally, but few and far between (sold by breakers, as Cee Jay said). Get the part number (don’t have the parts catalog handy) and try googling for it, you might get lucky. Just make sure to check any pictures carefully, no need to buy one in worse shape than your own.
Old Dec 14, 2022 | 08:39 AM
restd's Avatar
thank you, ill dig out the part number and start my search. Also will try upholster folks and see what they say. Appreciate the feedback.
Old Dec 16, 2022 | 01:54 PM
Tracee's Avatar
If it isn't torn / missing pieces, can't see why any upholstery shop couldn't glue the original material back down (thinking the endless posts about dash leather shrinkage...).
Old Dec 16, 2022 | 02:53 PM
beefheart's Avatar
Default Torn and shrunken leather
I think looking at the pictures, repairing the existing material is a no go
Old Aug 13, 2025 | 09:22 AM
Circumnavigator's Avatar
Anyone come up with a part number for this panel?
Edit: I found it.
Interior Quarter Panel Trim Panel (Rear, Lower)
Part Number: C2P17408RGH
Supersession(s): C2P10242RGH
Baaaahahahhaa $2k for new part.
Old Aug 13, 2025 | 10:47 AM
unklebuck's Avatar
I recently took mine apart to replace it as the seat had rubbed against it, not a difficult job to remove.
Check with these guys, they are usually pretty handy for parts or having unlinsted stock.
This is for a couple but you can still message them or call them.
https://www.ebay.com/itm/236174390703
Old Aug 13, 2025 | 03:22 PM
Bill400's Avatar
@restd The damage is not unusual for Florida and Texas cars.
Part numbers are different for coupe and convertible. Part number may not help your search.
Use the OEM nomenclature: Interior quarter trim panel (rear lower).
Used panels should come with working sliding cover/doors or be discounted, dollars off.
If doors are missing: suspect damaged track. More discount if you want to disassemble and reuse your track.
Unless you are lucky enough to find a pristine replacement:
1. remove your quarter panels for inspection, and if good, repair.
2. locate black leather or leatherette suitable for repair.
Imitation is easy to find. The real thing may be salvaged from damaged XK, XF or other parts.
3. Carry the panels and material to a shop or do it yourself.
Keep us posted on your results.
jean HJ
Jan 9, 2022 06:10 AM
roncking
May 3, 2021 07:37 AM
rhemler
Sep 5, 2019 06:07 PM
Cruzer56
E type ( XK-E )
May 18, 2016 06:30 PM
