remove center vents
Old Jul 11, 2017 | 09:28 AM
RedRider48's Avatar
Default remove center vents
Hey Folks,
I want to replace the center AC vents (above the Nav screen) in my '08 XK-R. My original is missing a tab.
Anyone "been there done that" and can offer tips?
Attached Thumbnails remove center vents-img_1115.jpg   remove center vents-img_1098.jpg
Old Jul 11, 2017 | 10:42 AM
Stuart S's Avatar
I'd remove the other tab. Much easier and cheaper than to R&R the existing unit.
But if you've already bought the replacement ...
Old Jul 11, 2017 | 11:05 AM
RedRider48's Avatar
Yeah, I have a nice replacement as seen. I would replace the "tab" if I was assured I could remove it without damage to it or the vanes.
I'll take a good look at it, anyway. Thanks for your comments.
A good look at it reveals the "tab" is sandwiched in the vane. Doesn't look like it will come out without a fight LOL!
Old Jul 11, 2017 | 11:14 AM
ajzride's Avatar
It just pops out.
Old Jul 11, 2017 | 12:06 PM
RedRider48's Avatar
Originally Posted by ajzride
It just pops out.
Yeah, it might "pop out" after you remove the wood facia trim.
Old Jul 11, 2017 | 06:56 PM
Cee Jay's Avatar
I also think it just Pops Out, but I'm not gonna try it on mine.............
Old Jul 11, 2017 | 07:48 PM
RedRider48's Avatar
OK, here are two more views. Need to remove the facia trim first to enable it to "pop out"
Attached Thumbnails remove center vents-xk-center-vents.jpg   remove center vents-xk-center-vents.jpg
Old Jul 11, 2017 | 07:54 PM
kj07xk's Avatar
Get yourself a set of trim removal tools, cheap on ebay, make sure they're the plastic ones, and carefully pry the trim off. Work from bottom to top. Taken mine off twice.
Old Jul 11, 2017 | 08:00 PM
RedRider48's Avatar
Thanks for the tip. I do have the trim removal tools.
Will start from the bottom of the facia and pry both sides at once and work upwards?
Old Jul 12, 2017 | 12:08 AM
kj07xk's Avatar
I started on one side, passenger I think, worked up about half way, then started the other side and worked it up half way. Then back to the passenger side and worked it up to the top, and then back to the other an worked it up to the top. Finally work the top free.
