ridiculous pricing for an oil plug!
Old Mar 22, 2018 | 08:20 AM
peterv8's Avatar
Default ridiculous pricing for an oil plug!
Needed a new oil plug and called nearest Jag dealer, they wanted over $20 for it!!
Called a local car shop like Autozone and they had it for $4!:-)
Old Mar 22, 2018 | 08:41 AM
khsjsilver's Avatar
It is unbelievable how expensive certain parts are from Jaguar.
I am looking for the little oval plastic part that is the Access Cover to the manual Convertible Top C2P21483AMN. Jaguar want $60 for the part!! It's a little piece of plastic!!
Ken
Old Mar 22, 2018 | 12:06 PM
Rick'sJag's Avatar
The auto parts chain stores have parts, that will fit. In example I shopped Advance Auto Parts, their price for brake pads and calipers is $100. per axel. Same for air filters, batteries, and other standard maintenance parts.
Old Mar 22, 2018 | 01:47 PM
user 2029223's Avatar
Banned
You know those little push pin fasteners that hold the plastic access panels under the hood? Well I had a dealer in Orlando price them at $10 each. Kind of makes your eyes water don't it.
Old Mar 22, 2018 | 02:01 PM
TexasTraveler's Avatar
LOL, especially when you can get 10 for $15
Amazon Amazon
Also, just in case someone was wondering the plastic bolt caps that cover the nuts for the tail lights on the inside of boot/trunk can be found cheap as well...
Amazon Amazon
Old Mar 22, 2018 | 02:11 PM
sparky fuze's Avatar
It would make for a very interesting exercise if someone were to price every single part required to build an entire car using prices from the Jaguar parts department, to see what the total cost of an non-assembled car would be.
Any guesses on the over/under at $500,000.00!
Old Mar 22, 2018 | 02:54 PM
jahummer's Avatar
Ken
Hope you won’t need Mercedes or Infiniti parts! Had 2 Infiniti door cards replaced under warranty recently at a cost of four grand not including labor and a Mercedes arm rest was several hundred.
Old Mar 22, 2018 | 04:38 PM
JBzXJ40's Avatar
You can get the O-ring on the oil drain plug separately.
I used to give the drain plug back and ask for this o-ring when vehicles came in for service, and yes its ridiculous what they charge for some things...... but this is nature in the world of branding.
It's no difference in buying a smart phone for $1,000 when you can buy one for $200 that does the exact same thing....
Old Mar 25, 2018 | 03:20 PM
IanXF's Avatar
Im asking this, why would you change the drain plug on every oil change its metal with an O ring , I cant see it being a problem unless you strip the threads. Just wondering why
Old Mar 25, 2018 | 03:44 PM
peterv8's Avatar
Cause rubber ages!
Old Mar 25, 2018 | 03:49 PM
Cee Jay's Avatar
Originally Posted by peterv8
Cause rubber ages!
Naw, what Ian asked is why change the metal part when a forty-cent O-ring would suffice.
Old Mar 25, 2018 | 04:37 PM
IanXF's Avatar
Exactly I was asking about the bolt on my 08 and every previous Jag I’ve only replaced the o ring when needed
Old Mar 25, 2018 | 05:03 PM
peterv8's Avatar
Sorry, missunderstood!:-)
I would never pay the OEM price for a oil plug but for $4 I like the vulked on rubber seal better then a 40 cent O-ring.:-)
Old Mar 26, 2018 | 01:40 AM
JagV8's Avatar
You wouldn't and I wouldn't, but it's the sort of thing they do at a dealer, perhaps to allow for the existing one having been over-tightened.
(I had your thought on my STR about 8 years ago. Bought ONE plug and on removing the existing one figured both it and the new one were fine. Didn't buy any more drain plugs.)
Old Mar 26, 2018 | 05:13 AM
peterv8's Avatar
Had a closer look at the oil plug and as you say it's just an O-ring! I thought the OEM plug had the rubber seal vulked/pressed on the bolt!?:-)
Well, you live and learn!:-D
It's even more ridiculous of Jaguar to have the customer pay for a whole new bolt when they could just replace the seal!
Old Mar 26, 2018 | 05:20 AM
IanXF's Avatar
Agreed
Cabel
Apr 29, 2017 04:01 PM
j_bond
Mar 21, 2011 06:19 PM
tadpole
Feb 27, 2011 09:52 PM
