service required?
Old May 9, 2014 | 07:09 AM
bobdr1's Avatar
Default service required?
Message just started coming up when starting car SERVICE REQUIRED. 2010 xk had oil changed 11 months ago, has 4k miles on oil. Is this service message for an oil change or possibly other service and how do I find out? was planning on having INDY change oil soon, don't want to spend half a day taking it to dealer. thanks
Old May 9, 2014 | 07:41 AM
Here is the explanation of how the SERVICE INTERVAL INDICATOR operates and the reset procedure:
It's a 'nag' message and not a sophisticated monitoring system indicating a fault.
Old May 11, 2014 | 11:50 AM
bobdr1's Avatar
Ok , I have tried doing this set of instructions at least a dozen times in past 2 days and nothing happens. Also the message service required in xxxx miles was never displayed prior to service required message coming up. Don't know if that has anything to do with it. Suggestions? thanks again
Old May 20, 2014 | 09:38 PM
Quebecjag's Avatar
Just got the same message too!!!
I have to stop by the dealer when i'll pass by.
I let you know whatever they will tell me
Guy
Old May 21, 2014 | 03:11 AM
Ngarara's Avatar
I believe it works on time as well as distance, since the car is supposed to be serviced every 12 months or xx miles. You get the "SERVICE REQUIRED IN xxx MILES" if you're close to the distance limit - if 12 months is coming up, you just get "SERVICE REQUIRED". That's what I got about a week before my 12-month service interval was up.
Old May 21, 2014 | 05:16 AM
Quebecjag's Avatar
The problem is the car got serviced just before I put it in the garage for the winter. I have use it for 3 weeks only since. I guess the mechanic didn't reset the program?
Guy
Old May 21, 2014 | 09:17 AM
Lothar52's Avatar
Guy
I would take it in, tell them what happened and tell them if its a nag fault you dont want charged anything for it!
Loth
Old May 21, 2014 | 12:31 PM
Octurbo's Avatar
Guy
Yes, they forgot to reset it. Simple procedure for them- takes 1 min
Old May 21, 2014 | 04:20 PM
bobdr1's Avatar
thanks guys but still this does not help me get rid of the stupid thing. Any other ideas or will i have to go to dealer to reset it. Instructions suggested prior do nothing! thanks
Old May 21, 2014 | 09:02 PM
tberg's Avatar
On the 2010 XKR coupe I just picked up last night, same service message. Took it to my indie mechanic, he reset in less than a minute and it's gone. You don't need the dealer to do it.
Old May 22, 2014 | 01:34 PM
Ngarara's Avatar
Dealers won't reset it without doing a service - I had a big argument with my local service centre when they removed the battery to give it a deep charge and the service message came up as soon as they put the battery back. I'd just bought the car and it had been serviced only 2 weeks earlier - they refused to reset the service interval until I got the dealer that sold me the car to send them proof of service!
Old Jul 20, 2014 | 05:13 PM
ddsski's Avatar
You have 3 seconds, that's the trick. The split second you press starter, immediately press trip indicator and rear fog button. I mean immediately!!
Old Jul 28, 2014 | 05:49 PM
bobdr1's Avatar
okay, do you keep the rear fog lamp pressed while you press the start button then let it go and repress it at the same time you press the button in the turn signal stalk which is the computer trip set button?
Old Jul 28, 2014 | 06:14 PM
Ngarara's Avatar
Yup, that's it
Old Jul 29, 2014 | 08:32 AM
Zandolini's Avatar
Does this procedure work on a 2009 XK? I've tried at least 25 times with no luck! And I'm quick like a ninga!
Old Jul 29, 2014 | 12:33 PM
Ngarara's Avatar
That procedure was originally documented for the XF, so it's possible that it only works on later XKs. Rahtok and scm said it worked on their 2010s, HouTexJag said it worked on his 2013. Brutal (certified tech) said it should work on all XKs.
Jpav27
US Northeast
Dec 17, 2021 05:40 AM
Chuck Schexnayder
Sep 18, 2015 03:10 PM
mrsimpson
Sep 15, 2015 01:10 PM
teacoff
Sep 10, 2015 08:25 AM
1964Daimler
Sep 9, 2015 04:50 PM
