Simple A/C Condenser Drain Fix
Old Jan 27, 2015 | 03:43 PM
hloucks's Avatar
Default Simple A/C Condenser Drain Fix
After noticing the dreaded condensate water in the passenger footwell of my '07 XKR (14k miles) from clogged A/C drain tube, I diligently checked the forum and found that I needed to: either drop the tranny and update the A/C drain hose; remove some exhaust parts and cut off the end of the drain hose; or add a new DIY drain hose behind the carpet in the passenger footwell. OK, says I: put in the DIY drain and that way, you can access and clean it easier if it clogs again.
So, looking in to the footwell with carpet removed, I see the little triangular funnel on top of the drain tube over the tranny in the center of the dash. See the low, black piece in left center of pic. Hmm. Maybe if I whacked it ( I used a 12" x 1/2" steel rod) it might loosen up the tube and start draining. I really didn't want to drill holes in my mint XKR floorboards. Sure enough, a couple whacks resulted in a fine half pint of drainage onto the garage floor. Problem solved, at least for now, and all it takes is pulling back the carpet and whacking the tube a couple times. Less than 10min work. It's been draining fine for over a week now.
Attached Thumbnails Simple A/C Condenser Drain Fix-img_9962.jpg
Old Jan 28, 2015 | 05:13 AM
Harve,
I've moved your thread from XK8/XKR (1996-2006) to XK/XKR (2006 onwards) forum. This is the place for posts about your model.
Old Jan 28, 2015 | 06:24 PM
sov211's Avatar
This is great information but I wonder if you could clarify exactly where the triangular piece is - for the life of me I cannot identify it in your photo! Where exactly do we whack???
Old Jan 28, 2015 | 06:41 PM
powerhouse's Avatar
I can't see it either in the picture, can you edit your picture and circle or highlight where it is or another pic.
The only thing i see in your picture that looks like a pipe is where i have the arrow pointing to. Is this it.
Attached Thumbnails Simple A/C Condenser Drain Fix-drain-tube.jpg
Old Jan 28, 2015 | 07:02 PM
jahummer's Avatar
+1 thank you for the useful information, but please make a mark on the photo to ID what you are referring to. Thanks.
Old Jan 28, 2015 | 08:21 PM
Cee Jay's Avatar
I do believe this is the drain relief in the air box where the line is contained.
Old Jan 28, 2015 | 08:34 PM
jagtoes's Avatar
So far I don't have this problem and hopefully it has been corrected in MY. I was thinking though why not become an auto surgeon. If you look at how orthoscopic surgery is done why not use a bore scope to find the duckbill and one of those remote pick tools to squeeze it open. Don't know if it would work but I would bet at least you can see the problem with the bore scope. My 2 cents here.
Old Jan 28, 2015 | 10:21 PM
DpezXK8's Avatar
I think he means the area I circled in red.
It looks like the area he mentioned, left center of photo and is probably connected to the drain tube. Black thing hanging down in the center of the dash but maybe he can confirm.
Attached Thumbnails Simple A/C Condenser Drain Fix-drain.jpg
Old Jan 29, 2015 | 04:05 AM
powerhouse's Avatar
Hloucks, you say "I see the little triangular funnel on top of the drain tube over the tranny in the center of the dash", can you see the drain tube itself.
So now we have 3 different ideas of where the drain pipe might be, if this a quick and easy solution is would be great. Could make up an air hose connection to give it a good blow now and again. Has anyone had a look at theirs yet.
Old Jan 30, 2015 | 10:14 AM
hloucks's Avatar
Default Quick A/C Drain Fix Whack Area
Sorry guys, I should have been more clear regarding the area. Yes, DpezXK8 circled the correct area for the drain in red. The black plastic condenser housing has a little triangular shaped "funnel" over the center of the tranny tunnel that has the drain tube attached to the bottom. You can't see the drain tube from the passenger foot well, but you can easily see the funnel and get to it for a little whacking. I wouldn't recommend hitting it too hard as I guess it could break. I hit it 5 or 6 times about as hard as I would hit a finish nail in carpentry. The car is still draining properly now after a couple weeks.
Good luck,
Harve
Old Jan 30, 2015 | 11:31 AM
powerhouse's Avatar
Good luck,
Harve
So this is the funnel where the water gathers and then goes out through the drain tube. What about if a small hole was put in this funnel, would water come out, or a hole the size of a small cleaning wire (coat hanger) put in to clean the tube. A air hose on/off connection could be another option, for blowing it out, wonder would it work. The previous owner had the fix done as i have the receipts, so hopefully it wont happen again.
Old Jan 30, 2015 | 10:59 PM
RedRider48's Avatar
Powerhouse, you took the idea right out of my brain! If, in fact, the hose is on the other side of that "triangle", why not use a Dremel and surgically cut out and gain access?
Old Jan 31, 2015 | 07:40 AM
powerhouse's Avatar
Who's going to be the first to operate, if the hose is just behind this area, what a save of time and money, go on someone give it a try and pics.
Old Jan 31, 2015 | 10:26 AM
guy's Avatar
guy
What a good idea. I'm reluctant to use an air valve fitting for fear of using too much pressure, but a plug covering an access point for a pipe cleaner might just do the trick. Again, good thinking.
Old Jun 10, 2015 | 08:56 PM
GovtSlug's Avatar
Hloucks, your solution sounded way too easy, but I took my socket extension, whacked the plastic a few times and water started pouring onto my garage floor! I don't know if it's fixed for good, but it's fixed for now! Thanks for the tip.
GovtSlug
Old Jun 11, 2015 | 09:49 AM
FrickenJag's Avatar
Former Sponsor
I'm next, going to whack mine tonight. Ha!
Old Jun 11, 2015 | 03:07 PM
hloucks's Avatar
GovtSlug --- glad the A/C drain "whacking" worked for you. My drain seems to be still working now 5 months after whacking. I'm keeping an eye on it, but no water in the passenger foot well yet, even with long trips in hot, humid weather. I'm still inclined to remove a section of exhaust, and cut off the end of the tube the next time I have the car up on jack stands. Good luck,
Harve Loucks
Old Jun 14, 2015 | 10:05 AM
FrickenJag's Avatar
Former Sponsor
Well, I gave it a try. Pulled carpet back and gave this plastic area a little knock or two with a long bar, and I started noticing drips under the car. Drove around for an hour or so in 95 deg and no drips inside. Seems this works. Well played guys. Thanks.
Old Jun 14, 2015 | 10:42 PM
Chaos236's Avatar
Did same mod to my Lexus 06 GS 300. Paid dealer $400 to do then Jag.
Old Jun 14, 2015 | 11:04 PM
RedRider48's Avatar
Is the another $400 dollar hammer story? LOL!
