Size of hex wrench for 2010 XKR front brakes = 9 mm
I have a quick question about the size of the hex wrench that is used in the two bolts that hold the outer caliper in place on the front brakes on a 2010 XKR. They are the standard non-Alcon 15" vented brake discs.
I have a set of wrenches that I used on my 2007 XK however the hex size on the 2010 seems to be larger.
Can anyone advise what the correct size is?
Thanks in advance
Thanks in advance
Received 3,127 Likes
This has been covered about a million times on these forums (I exaggerate only a little!) but if you have either the JLR 355 mm or 380 mm front brakes (pretty much standard across all North American JLR offerings since at least 2008) then you need a 9 mm hex driver to undo the caliper slide pins.
mlrtime99 (11-06-2021)
yelnats69
10-05-2014 03:09 PM
Britrover
07-21-2014 09:28 PM
