Spring Damper Mount
Old May 10, 2025 | 05:44 AM
Magnup's Avatar
Default Spring Damper Mount
Hello
Have a XKR convertibel from 2008
Have an issue with the damper, see attached photo there wsi something coming out looks like old honey.... Can that only be the mount ring, that is leaking and what is it ?
Thx Magnus And many thx to the folks running this forum....
Old May 10, 2025 | 07:13 AM
kj07xk's Avatar
Similar problem was posted awhile ago. Forget now exactly what it was, maybe the isolator dissolved?
Old May 10, 2025 | 07:33 AM
wymjym's Avatar
I replaced my mounts yesterday.
Yours are crumbling but when you say honey, are you implying they are gooy or crystal like?
WJ
Old May 10, 2025 | 11:55 AM
Stuart S's Avatar
Previously asked and answered. See this recent thread for how to replace your worn out parts, or show it to your Indy mechanic.
https://www.jaguarforums.com/forum/x...stions-279153/
@Magnup You need to create a signature that includes your location. See: New Members ***A Must Read***
Old May 11, 2025 | 07:23 AM
Magnup's Avatar
Hi it is more like dry jam,
Magnus
Old May 11, 2025 | 10:49 AM
Sean W's Avatar
It's shot either way and needs replacing. The shock absorber doesn't typically leak from the top, but I guess anything is possible. Removal is a bit of a pain and unless you're experienced in compressing springs, best use a shop.
Old May 12, 2025 | 06:45 AM
fritzthecat's Avatar
See my post here:
https://www.jaguarforums.com/forum/x...2/#post2741397
Since that time, another member posted doing his with a set of parts he got from ebay for less than $50! Which means I spent $300 too much! I’ll have to look for that post…
Rick
Old May 12, 2025 | 06:48 AM
Try this link for the parts:
https://www.jaguarforums.com/forum/xk-xkr-x150-33/bored-288916/#post2836531
post #8
Last edited by fritzthecat; May 12, 2025 at 06:52 AM. Reason: Better link, still can’t get it to go to the #8 post
Old May 25, 2025 | 03:15 AM
Magnup's Avatar
Default mount
Originally Posted by fritzthecat
Hi Fritz Thx for great info and photo on the mount and isolaltor, can you send me the link where to purchase this thx magnus
Old May 25, 2025 | 08:31 AM
@wymjym bought them here, and he says they’re the right ones for an XK convertible:
https://www.ebay.com/itm/314623695037
Apparently, the convertible ones are different than the ones for a coupe.
Old May 26, 2025 | 11:27 AM
wymjym's Avatar
@fritzthecat,
a bit of clarity here, I believe, based on jaguar parts manual and other's comments, that the mounts are exactly the same for the convertible and coupe.
Further, these mounts are also correct for the front and rear struts.
I have not replaced my rears as yet but do have a set waiting for the time I get inspired.
wj
Old May 27, 2025 | 07:24 AM
Originally Posted by wymjym
@fritzthecat,
wj
Weird. This site:
https://jaguar.oempartsonline.com/v-...ont-suspension
shows C2P23038 for the convertible and C2D51875 for the coupe. I believe you, since you’ve done the job yourself and it worked. But if the online parts catalog is wrong, what else is it wrong about?
Old May 27, 2025 | 08:00 AM
wymjym's Avatar
Even more confusion!
several UK jag sites show the c2d51875 number as having superceded the c2p10646/23038 designations.
wj
jal1234
Sep 1, 2022 12:42 AM
petercz
Jan 27, 2022 03:58 AM
baxtor
May 31, 2021 07:12 AM
DC52
Feb 22, 2021 08:19 PM
AlbBolivar
Dec 27, 2014 03:59 PM
