Steering wheel play?
Old 08-19-2016, 10:42 PM
pk4144's Avatar
Default Steering wheel play?
A quick one:
Met a fellow owner, drove his 2014 XK-- the steering response was tight, like flick-of-the wrist tight, less than 1/2 inch either way on the wheel.
Drove mine again and was very much aware of what would be "normal" play on an older car, maybe an inch and a half each way.
I've got a 2010 with 21,000 miles on it (his had about 12K). Is a little play normal, or is this a cause of concern? Haven't seen any threads on this in particular. I should also point out that I just swapped out to Continential Extreme Pro Contacts about a week ago. Much smoother ride.
Thanks as always...
Old 08-19-2016, 10:58 PM
fishbait1's Avatar
mine is a 2008 with approx. 39,000 miles and my steering is tight . also probably no more than 1/2". I know that with my chevy truck I can feel the slack in the wheel. I can feel nothing with the XK. I have to be conscious of looking away from where I am going.
1 1/2" either way seems excessive to me.
pk4144 (08-21-2016)
Old 08-20-2016, 07:49 AM
jagtoes's Avatar
Received 1,836 Likes on 1,231 Posts
I would check your tire pressures as with a softer riding tire you may be experiencing more side wall flex. Also do we assume you also got an alignment when you put the new tires on. I have 16K on my 2012 with Conti DWS and don't have a response play issue but the old Dunlops had a different feel.
pk4144 (08-21-2016)
Old 08-21-2016, 01:53 AM
pk4144's Avatar
Got an alignment, will double-check pressure. I was previously riding on the original Dunlops which were basically bald on the rears.
Old 08-21-2016, 10:30 PM
Fstbmw1's Avatar
My 07' with 49000km. has no play in the steering. If you tires and pressure are good, take it to an alignment shop and have them take a peek at the front end. There are a few 'maintenance' items that can cause some play in the steering.
Pilotman11
04-23-2016 12:50 PM
Humy
10-08-2013 10:38 AM
IronCobra
05-21-2013 01:44 PM
bubbawing
06-07-2007 02:28 PM
wayne64
05-16-2007 07:48 PM
Quick Reply: Steering wheel play?
