Steering wheel vibration when turning standing still
Old May 9, 2026 | 08:45 PM
bocatrip's Avatar
Default Steering wheel vibration when turning standing still
Recently I noticed that I get a vibration/shaking in the steering wheel when idling at a complete stop when I turn
the steering wheel to maneuver out of a parking spot. I have no
clue...There is no vibration in the steering wheel while driving. Is it a lose power steering belt? Any feedback would be greatly appreciated.
Old May 9, 2026 | 08:58 PM
wymjym's Avatar
Maybe air in the ps system. First approach to resolve would be to replace ps fluid with new. ( if car has over 50k miles)
wj
Old May 9, 2026 | 09:09 PM
bocatrip's Avatar
wj
25,000 miles. Thanks for the suggestion.
Old May 10, 2026 | 08:12 AM
guy's Avatar
guy
Agreed. Aged (and dirty) hydraulic fluid wouldn’t help.
And I wouldn’t stress the PS nor flat spot the tires by turning the wheel when not rolling.
Old May 10, 2026 | 11:42 AM
bocatrip's Avatar
Just checked the power steering fluid. Bright Red.
Old May 10, 2026 | 03:59 PM
guy's Avatar
guy
Fwiw.
https://berendsen.com.au/news/the-to...d-degradation/
cheers.
Old May 10, 2026 | 04:46 PM
bocatrip's Avatar
Thanks for the info Guy.... Of course water getting into the system as in brake fluid can always be an issue. I'll certainly look into a power steering flush with my Indy and go from there. The vibration is quite intermittent, but being proactive by changing the power steering fluid to avoid replacing a power steering pump would certainly be wise. Thanks again.
Old May 10, 2026 | 06:42 PM
RoverJoe's Avatar
Community Influencer
Tires get changed recently? Could just be a function of friction vs what it was before. Most cars get a bit of chatter in the wheel on certain surfaces with sticky enough tires.
Old Yesterday | 08:01 AM
mhminnich's Avatar
I occasionally get that sitting-still chatter on initial steering wheel movement. It's only the first few degrees of steering wheel movement, is not reproducable if I repeat the movement again, and only happens occasionally.
It therefore hasn't risen to the level of a "must fix" issue.
Old Yesterday | 09:43 AM
bocatrip's Avatar
Mine is also quite Intermittent. My tires are Michelin Pilot 4S with about 10,000 miles on them.
GGJag
Nov 1, 2024 05:16 AM
ant17
Aug 29, 2024 01:43 PM
Vinnyboy
Mar 29, 2023 09:19 AM
Wayne Lea
Jan 15, 2022 06:14 AM
f1champ
May 4, 2016 12:25 PM
