Thermostat
Old Feb 23, 2012 | 09:09 AM
dkeuper's Avatar
Default Thermostat
Did anyone ever tried this Duralast thermostat:
Duralast/Thermostat (54892) | 2007 Jaguar XK 8 Cylinders 4.2L SFI DOHC | AutoZone.com
Might be it works better than the stock one.
2007-2009 Jaguar XK Thermostat – OES Genuine W0133-1817704 - Thermostat - OES Genuine
Old Feb 23, 2012 | 09:56 AM
rscultho's Avatar
Originally Posted by dkeuper
Autozone thermostats are cheaply made...quality is not good.
Old Feb 23, 2012 | 11:26 AM
dkeuper's Avatar
Is there any other solution or better Thermostat, what about Stant?
Old Feb 23, 2012 | 11:59 AM
mosesbotbol's Avatar
My mechanic swears by sticking with OEM on Jags.
Old Feb 23, 2012 | 12:04 PM
CleverName's Avatar
Stants have been around forever, and not really known for anythings but a straight inexpensive OEM replacement.
I have wondered about these folks, but have not heard from any users, so they too may be pure hype
MotoRad - Fail Safe® Thermostat
Vince
Old Feb 23, 2012 | 02:15 PM
rscultho's Avatar
I agree here.
I have only had to replace one thermostat in a Jag. Fortunately, I live only about 5 miles from a Jaguar parts dealer (Coventry West) so I get real Jaguar stuff from them. They have a website - you can order parts from them - everything from oil filters to transmissions. They sell new and used parts cheaper than what you will get it from the dealer.
I also get stuff Nalley Jaguar in Roswell, Georgia. They give a %15 discount by mentioning that you are a Jag forums member. There used to be a guy named Dan that we dealt with but he has moved on; however they still honor the discount.
I would get a real Jag thermostat for my XK/XKR.
Old Feb 23, 2012 | 02:55 PM
dkeuper's Avatar
Is it ok just to replace the thermostat or should I replace the thermostat cover as well, if I stay with the stock parts ?
Old Feb 23, 2012 | 03:37 PM
Mike V's Avatar
Default Seal
Not the cover but definitely get the seal, only a couple bucks.
Old Feb 23, 2012 | 05:01 PM
CleverName's Avatar
Davids the man at Nalley to talk to now.... He has taken good care of me.
Vince
Old Feb 24, 2012 | 06:33 AM
dkeuper's Avatar
Is there actually any indicator for overheating?
What happens if the engine gets to hot, will just the CE light go on?
Dirk
Old Mar 5, 2012 | 05:57 PM
CleverName's Avatar
Dirk
Post resurrection, sorry as I just ran across this info:
Your message center will alert you. I has two stages of alert, the first is at 244.4(F) degrees(118C) it displays an amber warning triangle and says "Engine Temperature High"
At 247 degrees (119.4C) the triangle goes red and warning is "Engine Overheating".
Just passing on stuff.... even if it is a tad late...
Vince
Old Mar 5, 2012 | 07:08 PM
plums's Avatar
Just 2.6*F between amber and red?
It should be
amber="pull over right this freakin' minute!"
red="now you've done it, get out your wallet"
Old Jul 1, 2012 | 09:53 PM
2007 Rick's Avatar
Default Quote
It should be
Now that's funny !!!!!
Old Oct 12, 2012 | 04:54 AM
AlexUSA8's Avatar
I have a P0128 code, I checked my coolant level and there are no issues there, nor am I spilling any coolant. Should I consider replacing the Thermostat as a solution?
hoodun
Feb 20, 2023 05:52 AM
mikiep
Dec 20, 2019 07:37 PM
Lubrication
Oct 1, 2015 03:56 AM
zoozth
Sep 29, 2015 07:28 AM
hoodun
Sep 28, 2015 08:32 PM
