TPMS
Old Sep 28, 2022 | 02:55 PM
gtophen's Avatar
Default TPMS
In my new to me '09 xk the only problem I have is an intermittent " Check all tire pressures" indication. This will come on for about 2 minutes, go away for an hour or a day and then reappear. The dealer installed 4 new TPM's. Any ideas?
Old Sep 28, 2022 | 03:15 PM
arenaej's Avatar
Search is your friend…
Old Sep 28, 2022 | 03:58 PM
Cee Jay's Avatar
https://www.jaguarforums.com/forum/s...rchid=14639916
Old Sep 28, 2022 | 08:19 PM
jagtoes's Avatar
Check the spare tire.
Old Sep 28, 2022 | 08:30 PM
Cee Jay's Avatar
These spares don't have initiators near them. Therefore, don't work towards the system until they spin on an axle.
Old Sep 28, 2022 | 08:55 PM
Stuart S's Avatar
First thing to do with any electrical problem is to make sure your car battery is fully charged. A low battery can cause all sorts of problems.
Take it back to the dealer and tell them to scan each wheel sensor for remaining battery life. They may have sold you old sensors that were sitting on the shelf for years losing battery life.
There are three components in the TPMS system: (1) wheel sensors (transmitters); (2) TPMS receiver (antenna), and (3)TPMS Module.
Try this TPMS hack, you might get lucky. Do them in order of difficulty, easiest first, as detailed below: wheel sensors, TPMS Module, TPMS receiver.
Note that TPMS sensors need no programming.
1. Inflate all 4 tires to 42 lbs when cold.
2. Drive around for 15 -20 minutes to automatically recalibrate your TPMS wheel sensors.
3. Reduce the inflation to the pressures specified on the driver's door jamb.
Hopefully, that solved your problem. If not, the next thing to do is reset the TPMS module from the fuse box behind the center section of the rear seat. If that doesn't solve it, check the wiring at the TPMS receiver, which is behind the front bumper cover. See this old thread for details:
https://www.jaguarforums.com/forum/x...s-fault-55340/
Old Sep 29, 2022 | 08:42 AM
Cee Jay's Avatar
Oopsies, you forgot the initiators. The tennis racket things inside the wheel well liners.
Old Sep 29, 2022 | 12:22 PM
tmich's Avatar
If all are failed 99% that it is a faulty TPMS module. Been there, done that. Buy a new one, replace (easy thing - 2 screws behind rear seats) and of you go.
Old Sep 29, 2022 | 01:11 PM
j.w.s's Avatar
Can anyone else confirm that the TPMS module is plug-and play, with no "dealer reprogramming" required? If so then it's a fairly inexpensive thing to swap out, though I will add that cleaning electrical contacts is always my first attempted fix, before replacing anything.
Old Sep 29, 2022 | 01:27 PM
tmich's Avatar
No reprogramming needed for TPMS related issues.
Old Sep 29, 2022 | 03:42 PM
CurtJ's Avatar
I also have the TPMS cycling issue. Doesn't bother me much, since I manually check the tire weekly and I don't care about seeing the clock that much. I suspect I'll get around to fixing it some day, and at that time I'll be referring to this thread: https://www.jaguarforums.com/forum/x...rtible-261907/
oldole
Jan 25, 2022 11:35 AM
Sean W
May 27, 2017 12:08 PM
Mi2012gato
Feb 17, 2016 01:37 PM
richzak
May 24, 2014 12:51 AM
Profit
Jan 24, 2011 06:04 PM
