Washer pumps not working on my XKR
Old Jul 7, 2019 | 08:53 AM
Jungocat's Avatar
Default Washer pumps not working on my XKR
Hey everyone,
After troubleshooting this myself and then again by a local Jag shop, I went ahead and purchased a new washer pump motor for the windshield (the headlight washer pump WAS working at the time). I then replaced the pump and now neither of the pumps work. I checked the fuses as per the manual and they are intact.
Any suggestions before I head back to my mechanic??
Old Jul 7, 2019 | 11:27 AM
Reverend Sam's Avatar
The headlight washer pump doesn't come on every time you squirt the windshield. I don't know the exact parameters. Maybe the headlights have to be on? I'm not sure.
Do you have a multimeter? I think you need to check the voltage at the washer pump connector. If you don't have voltage there, I'd check the fuse with the meter. Fuses can look good even though they aren't. If you DO have voltage at the pump connector, maybe you just got a bad pump.
In the stickies at the top of this forum you'll find the electrical guide. Open it up in Acrobat reader and search for "washer". I got 10 hits. It looks like a pretty simple system, so it should be easy to figure out.
Old Jul 7, 2019 | 02:50 PM
Jungocat's Avatar
Default Washer pump
Thanks. I think my multimeter isn’t working! That could be an issue for sure. I got the headlight washers working. It’s a weird 1/6 activation thing.
Old Jul 7, 2019 | 03:06 PM
Cee Jay's Avatar
Read the manual????
Old Jul 7, 2019 | 04:27 PM
Cee Jay, some people buy used cars and the manual is missing. Or they are posting from work and the manual is in their car, in their garage, at their house 20 miles away.
I've been on other forums (saabcentral.com) where the members were absolute jerks to people who joined and asked questions. The regular members would belittle anyone who asked a question with comments like "read the damn manual, we're not your babysitter", "Did you try using the search function?", and "This question has been answered already!"
That was really weird to me. I went from jaguarforums to saabcentral (and other forums) and the members on those forums were ******** and typical internet trolls. I rarely posted on those forums, and if I did, I made sure I did my research first. Every one of those forums was slow and dull, with not many posts per day. I only used them when I had to because I wasn't going to subject myself to the abuse.
Jungocat only has 13 posts in a year of membership. I hope that's not because when he first joined to ask a question someone told him to read the manual.
Old Jul 8, 2019 | 10:48 AM
Jungocat's Avatar
Thanks Reverend How did you know I was detached from my manual? I did know the silly sequence of the headlight washers.....and the 10 min gap between usage - that makes sense......to a Jag engineer maybe. I solved it - poor connection.
The issue still remains with the regular (now replaced) washer pump. I have a few more tricks to try today - and when I post the solution, whether I look like a dope or not is still TBD
Old Jul 8, 2019 | 01:55 PM
Sean W's Avatar
I'm also not a fan of sarcasm unless it's in fun. Cee Jay tends to lead the pack in that regard with his love of all things Apple and Michelin and I'm sure he's self aware, however, you indicated you had the manual in your above quote. The specific page with the relevant info was therefore referenced by him. Everyone has their style. Getting/giving help is ultimately what's important. Nuff said I hope.
Regarding looking like a dope once you solve, not to worry. I lead the pack in that regard and curious to see how you solve it.
Old Jul 17, 2019 | 02:06 AM
badicedog's Avatar
What sequence do you speak of? I read the manual and still can't figure out the headlight washers....lol
Old Feb 19, 2022 | 08:21 AM
fezco999's Avatar
Hey everyone,
hi jungocat,
unrelated to the correction however relation to parts:
i am wanting to know where you had ordered your part for the washer pump, mine seems to just drizzle out like small toddler drawling on to my windshield.
any help would be great.
thanks
Old Feb 19, 2022 | 09:21 AM
Stuart S's Avatar
fezco999,
You're in Scotland and Jungocat is in Canada. Why pay shipping from Canada?
One of this Forum's sponsors is SNG Barratt, a parts vendor headquartered in the UK. I suggest that you call them, and ask if there's discount for a Forum member.
https://www.sngbarratt.com/English/#/uk/home
Good luck!
Stuart
Old Feb 19, 2022 | 09:24 AM
Stuart S's Avatar
Before buying a new pump, make sure that there's no blockage in the line from the pump to the windshield.
Old Feb 19, 2022 | 09:53 AM
Originally Posted by fezco999
..... washer pump, mine seems to just drizzle out like small toddler drawling on to my windshield. .....
Welcome to the forums fezco999,
The windscreen and headlamp washer pumps usually either work or fail - they generally don't slow down. I'd take the wheelarch liner off, disconnect the outlet pipe (arrowed in red) and check pump delivery before buying a new one.
As Stuart suggests, it could be a blockage in the line.
Old Feb 19, 2022 | 10:16 AM
fezco999's Avatar
thank you both Stuart and GGG for the assistance,
i will keep you updated on outcome.
fezco999
Old Oct 3, 2022 | 01:42 PM
sjpalm's Avatar
fezco999
Hi Fezco,
what was the solution please?
I have the same issue.
Old Oct 4, 2022 | 05:27 AM
fezco999's Avatar
HI SJPALM,
the issue was resolved by cleaning out the pipes and replacing the motor, (i replaced the motor to be on the safe side, was not needed to be replaced) .
very annoying to get to as you need to remove a few things to gain access. but a proper mechanic can do this.
Regards
Old Nov 14, 2024 | 10:44 AM
davidedney123's Avatar
OK this is an old thread but other people may find this useful. I just replaced the headlamp powerwash / headlight washer motor pump on my X150 and I couldn't be sure which compatible parts fitted so I bough the Jaguar OE part, part no C2S4086 for £67
Taking the old one out the Ford part no on it is 5w93-13k082-aa / 5W9313K082AA and 3rd party replacements start at £20
I've heard of people buying the ford part and the connectors being different but I can confirm that the Ford part no above is exactly what you want.
It's very easy to change. OSF wheel off, half a dozen T25 bolts out of the wheel arch liner, pull it out of the way, and you can just pull the pump free. The washer pump is higher up and over towards the wing and tucked in, so is every so slightly fiddle to remove. No gauze on the powerwash gromet to clean but while you're there it's worth removing the screenwash pump motor too and cleaning the gauze.
Rod Terra
Jun 14, 2020 04:28 AM
Dav2ison
Apr 9, 2019 07:27 AM
TreVoRTasmin
Feb 17, 2016 07:01 PM
lofty
Jan 5, 2009 05:40 AM
