What are the additional FAKRA inputs for?
Old Jun 5, 2018 | 12:15 PM
Cee Jay's Avatar
Question What are the additional FAKRA inputs for?
OK, here's a question for those who are WAY more knowledgeable than I;
On the back of the TSD there are Three FAKRA ports, Beige, Brown and Green.
One is for the Rear Camera (mine is turned on and using the brown one)
What are the other two used for?
AND, how could a person activate the other two to show whatever video source is hooked TO those FAKRA inputs? What would be any procedure to switching to those inputs?
Using those two extra FAKRA inputs opens up HUGE possibilities, such as using these wonderful things (there are many different ones available):
https://www.ebay.com/i/122467123241?chn=ps
Since the brown one is 'active', I can't see why there would be two additional with no connectivity/activation possible.
Someone PLEASE enlighten me!
Old Jun 5, 2018 | 04:35 PM
jahummer's Avatar
These assemblies were specified by JLR and manufactured by Alpine and designed to fit other models. . I believe one of the inputs is for the DVB TV tuner available in other markets and the other perhaps for RSE which was also on option in other markets and models. It is also not unusual in the automotive engineering industry to make options for potential future use that may never even be used, it’s cheaper to build and order one size fits all so to speak.
Old Jun 5, 2018 | 05:12 PM
Cee Jay's Avatar
Originally Posted by jahummer
......... I believe one of the inputs is for the DVB-S TV tuner available in other markets .........................
So then it'd make sense that it is 'turn-on-able'.
I do now recollect the DVB tuner stuff now, but I'd have zero idea where it'd be in SDD, and if I'd need a file to activate it.
Any more help out there?
Old Jun 5, 2018 | 05:13 PM
Cee Jay's Avatar
Aw yeah, NOW I seem to recall that someone from OZ or NZ turned something on and could watch TV-type stuff.
Cambo? Someone else? I can't remember where to find that thread, and the SEARCH is.... lacking.
Old Jun 5, 2018 | 05:37 PM
kj07xk's Avatar
See post #9 in this thread:
https://www.jaguarforums.com/forum/x...08-xkr-198002/
Old Jun 5, 2018 | 05:39 PM
jahummer's Avatar
Post # 9
Old Jun 5, 2018 | 05:54 PM
Cee Jay's Avatar
THAT'S the one! Thanks guys.
So therefore, there IS a way to turn on the Video Input, although I don't care about any DVB TV stuff, I just need a way to have the video displayed.
CAMBO!
How do I get video turned on? I'll supply it to the FAKRA (which one?), I just need the ability to see it!
Teach me, oh master of stuff.
IF this works out, it'll be a MUCH easier way to have gauges displayed (and Google Maps, and this and that and whatever could be put on a portable device)
Old Jun 5, 2018 | 06:08 PM
jahummer's Avatar
The problem may be the switching is for modules in the MOST network you will not have fitted. Without a custom GUI I don’t think having the TV button enabled will actually switch to that input without the module fitted. This certainly would be a nice alternative to the GVIF split of the NAVI.
If I ever have time, I may get around to re writing the TSD software GUI. But don’t hold your breath...
Old Jun 5, 2018 | 09:18 PM
Cee Jay's Avatar
Well, if not for the TV, there is still that other input for some reason or another. Also, since the Rear Camera switches without any external modules, why wouldn't the TV button do it? I'd assume, as if the Sirius/XM module was removed that the TSD would still try to swap to it, but "Unavailable" or something like that would show.
Old Jun 7, 2018 | 11:15 AM
Cee Jay's Avatar
THESE things:
Old Jun 7, 2018 | 11:54 PM
Cambo's Avatar
Green is the TV video image input.
If you enable the TV without having a TV module fitted, you get the TV menu on the screen, and when you go into the TV menu all the buttons/controls are there, but they don't do anything.
In principle you might get a picture on the screen if you connect a video source to the green input, and go into the TV menu, but you won't have any control over it. Also the picture is blocked unless the park brake is engaged.
The Beige input is superfluous, there is nothing in the touchscreen software for it. I'm not even sure why they added it because the screen from the XF doesn't have it at all. The screen from the Freelander 2 / LR2 up to 2012 (same-ish hardware) does have the same three fakra inputs, which is even more odd because the LR2 software does not support Reverse Camera or TV at all, nor rear seat entertainment or surround cameras.
There is a way of getting an image on the screen via those fakras but it's through the hidden menu / diagnostic menu. You won't be able to have a Video button in the normal menu like there is for AM/FM, DAB, SAT Radio, AUX, Portable Audio or TV, it just doesn't exist in the software.
And of course it's just a screen in this case, not a touchscreen that gives you control over anything.
Old Jun 8, 2018 | 02:23 PM
Cee Jay's Avatar
Well, that answered that. All I wanted was a video display generated by Android, mostly Torque.
Sad, I didn't even think about the Nanny TV-Only-With-Brake thing. Oh well for me.
Kejar7
May 29, 2017 10:23 PM
gotmoss89
Apr 24, 2014 12:41 PM
Jag Breeder
Aug 25, 2011 11:54 AM
beelab43
Jan 9, 2008 10:22 PM
princessoftx
16
Jun 29, 2007 03:25 AM
