What did you do to your X150 today?
Old Apr 12, 2026 | 08:26 PM
  #2721
mturner7's Avatar
Default New slotted/drilled front & rear brakes.
Decided to upgrade the brakes all around. I got a “Low Pad” Warning a couple weeks ago. I just got the car a month ago. The brakes work great, but wanted to investigate the Low Pad warning.
The rotors all looked either original or really old. The car has 119,000 miles on it and runs great. Got new sensors also.
Install them all, bleed the lines with Dot 4. Came out real nice. I think I’m going to get the calipers powered coated. Red or Yellow? I like red.
Old Apr 12, 2026 | 08:44 PM
  #2722
mturner7's Avatar
Default Very nice seats, where’d you get them? There not stock are they?
Finally got around to installing the ivory armrest
Side trim needs to be removed and also the key fob holder .
A total of 6 torq bolts for trim , 2 for key fob holder and 2 for the armrest
nice seats, where’d u get them?
Old Apr 24, 2026 | 06:02 AM
  #2723
Julesthejag's Avatar
Default 07 XKR Battery Replacement.
This is a common and easy job I know, but I did learn a few things that I wanted to document. My battery was giving me a sluggish start in the morning, but it fired up with no errors. I put this down to not driving it for about a week. Drove to work and then I left work about 4 hours later and again a sluggish start. I wanted to grab some gas, so headed over and squeezed in some 91 octane. Now she's dead, no start. Just a couple of clicks and multiple errors. Got a buddy to give me a jump start and it fired up ok. Errors went away and I drove home and parked it. Shut the car off and then restarted it no problem, no errors. I left it sit for a couple of hours and tried to start it with no joy. Ok, most likely a dead battery. Picked a new H8 and went to work on replacing it. No real issues putting the new one in, went to start it and off she goes running like a champ. The next task was the resets, parking brake no problem. It took me three times to get the passenger window to reset, but I got it. I tested the roof and it popped up about an inch and stopped. Now it won't open or close. The warning on the dash just says roof not latched. So I did a bit of online digging and found that if you hold the button for about a minute, it will eventually go. Never knew that. So after it started moving again I opened and closed it three times and finally on the last run, it operated correctly with all windows closing at the end. Again, not asking for help, just thought I'd post my experience and that's what I did to my X150 today!
Old Apr 24, 2026 | 08:44 AM
  #2724
McJag222's Avatar
Used Mothers California Gold Clay kit last evening - been putting clay bar off. Washed car in the afternoon and the upper surfaces hood, roof and hatch felt rough feel. Went out a bought two kits on sale. Spent hour and a half "baring" the car. Really easy (I was surprised) very little pressure applied - this stuff works really well. Paint work is really smooth and shiny. Used nearly one bottle (16 fluid ounce).
Old Apr 24, 2026 | 10:28 AM
  #2725
Cee Jay's Avatar
Originally Posted by Julesthejag
This is a common and easy job I know, but I did learn a few things that I wanted to document. My battery was giving me a sluggish start in the morning, ............. Ok, most likely a dead battery. ........... Again, not asking for help, just thought I'd post my experience and that's what I did to my X150 today!
Good job, and here is some sage advice after a battery replacement......... Batteries sit on trucks, in storage and in 'the back' of stores for sometimes a long time. It is ALWAYS recommended to FULLY charge a new battery before use. Since yours works right now, it should still get a complete top-off charge to make dang certain it is COMPLETELY full. This alone can help a new battery last much longer.
Old Apr 24, 2026 | 12:15 PM
  #2726
Correct, CeeJay! Gave it a full charge followed by a 15 mile drive to boot. I also noticed that when I first started it, after it had been running for a few minutes, the idle came down as expected but it idled funny initially. After driving it for 15 miles the idle was back to normal. I believe this is due to the car learning your driving style and how that is lost when you replace the battery.
Old Apr 24, 2026 | 04:41 PM
  #2727
HealeyJag's Avatar
I drove it to the restaurant that we went to last night...
after I left my credit card there,,,,
Old Apr 28, 2026 | 12:13 PM
  #2728
wymjym's Avatar
Finally replaced my hl assemblies. The old ones looked great until I compared them to the replacements I bought last year.
I showed a friend the old and new...got the eye roll thing!
but, I'm happy
wj
Jst2gtby
Apr 11, 2026 12:02 PM
Brock
Oct 3, 2018 08:48 PM
sgvkirbster
Sep 16, 2018 05:12 AM
CunninghamDrivers
E type ( XK-E )
Aug 6, 2016 08:51 PM
cat_as_trophy
Jun 2, 2014 10:31 PM
