What did you do to your X150 today?
Old Apr 14, 2019 | 12:44 AM
  #721
ralphwg's Avatar
Good hunting SLazz.
Old Apr 14, 2019 | 10:36 AM
  #722
Kongo1's Avatar
Just finished fixing the broken glove box damper issue using the cotter pin method.
Does anybody else's glove box door just barely hit the side of the center console at the bottom preventing it from dropping all the way? I took it back out twice to make sure it was aligned properly, everything seems lined up and it opens nicely but because of the damper working now it doesn't seem to be enough force to let it drop past the side of the center console like it did when the damper wasn't attached. When I push in the console piece it goes right by just fine.
No big deal just the last half inch.
Old Apr 14, 2019 | 11:39 AM
  #723
JackJohn's Avatar
Spent a stack of money with my favorite Jag Tech. Changed oil/filter; transmission oil/pan/filter/sealing sleeve; brake fluid flush; replaced lower control arm bushings/alignment.
Old Apr 14, 2019 | 06:24 PM
  #724
jahummer's Avatar
Default APR Carbon fiber wing installed
Installed a carbon fiber APR GTC-200 60" wing for extra rear end stability. About matches the XKR-S GT specs. Sorry pics aren't the best.
Old Apr 15, 2019 | 05:19 AM
  #725
steve_k_xk's Avatar
This car is definitely the real deal now loving that wing !!
Old Apr 15, 2019 | 06:13 AM
  #726
jagtoes's Avatar
Cool look and it needs some decals to make it more visible. Something with more color. Nice job.
Old Apr 15, 2019 | 05:26 PM
  #727
Simon Tan's Avatar
Haven't really had to do anything to the XK in a while other than drive and enjoy it, so I treated myself to a couple of nice custom key fobs from a leather worker out of the Czech Republic. You can also pick the Jag growler or leaper logo instead along with your name or initials, but I thought the 'R' logo was nice and minimalist since I already had the leaper key chain. Just wish I could've gotten a shade darker stain on the leather to match my truffle interior better. Still, it's a definite improvement over the scratched-up plastic chrome on the bare fobs.
Old Apr 16, 2019 | 03:58 AM
  #728
XK-Ahhh's Avatar
Default New bell & rotor set up
Using Alcon Calipers invested in new bells and rotors saving 16Kg in weight.
Brake set up 2006 XKR
Old Apr 30, 2019 | 12:20 PM
  #729
TexasTraveler's Avatar
Went to put my sunscreen up in the windshield today and noticed this... Looks like I will be searching for a new speaker grill...
Old Apr 30, 2019 | 12:56 PM
  #730
XJ8JR's Avatar
Care to share the details?
Old Apr 30, 2019 | 01:11 PM
  #731
shemp's Avatar
Annual oil change and a once over by the local Jag specialist.
Old Apr 30, 2019 | 10:58 PM
  #732
forrestgk's Avatar
I just replaced the speaker grill on my 2007 XK a few weeks ago. The problem with them is that the plastic degrades badly, because of exposure to sun. My one had a crack like yours. I knew it could be brittle so left it alone until I located a replacement. It's impossible (I found) to locate a used one from a salvager/EBAY, so I searched the Jaguar dealer listings and bought a new replacement for about $50. It arrived in a week from a dealer in Reno.
When I went to remove the old one, it didn't matter how careful I was, it just broke into multiple pieces. I was right to leave well alone until I had the replacement. Since I don't have the premium sound system, this covers nothing, so a little annoying, but the replacement was not hard to get and it now looks like new.
Old Apr 30, 2019 | 11:05 PM
  #733
forrestgk's Avatar
Old Apr 30, 2019 | 11:12 PM
  #734
forrestgk's Avatar
Installed sound deadening material to trunk.
Replaced front right wheel hub/bearing at Indy mechanic.
Replaced power steering reservoir/filter.
Old May 1, 2019 | 03:44 AM
  #735
XK-Ahhh's Avatar
Sure - Custom made - by Wortec in the UK. Available through the excellent Swallows Racing organisation in Rooksbridge, Bristol https://www.swallows-jag.co.uk/performance. I use Pagid RS endurance pads.
Old May 1, 2019 | 07:47 AM
  #736
Would you happen to have a link to part or dealer you bought yours from? Everything I have seen from my quick search is $150+
Old May 3, 2019 | 10:31 AM
  #737
Gordo1968's Avatar
Turned into the Hulk and sheared my shift lever taking the knob off!
Old May 3, 2019 | 02:09 PM
  #738
Ngarara's Avatar
Old May 3, 2019 | 02:12 PM
  #739
shemp's Avatar
They went to the Rotary shifter because of guys like you!
Old May 3, 2019 | 04:58 PM
  #740
Stuart S's Avatar
I had two very small door dings in the right rear quarter panel expertly removed yesterday by suction method and am very pleased. It's impossible to tell that they were there. I suspect, but can't prove (and won't try to), that they were caused by my wife while taking stuff out of the back seat of her MDX. Since I want to keep my XKR from getting dinged again, I made a side protector using a $1 foam plastic pool noodle that I bought from the Dollar Store and a set of 4 suction cup hold downs that I bought from Amazon for $12.61. The 6" suction cups are non- marking and are easy to put on and take off and the loop is easy to adjust. Inexpensive and effective protection.
