What did you do to your X150 today?
Old Feb 6, 2019 | 07:23 PM
  #661
flyc2c's Avatar
Changed the oil and filter. Washed. Speed dry
Old Feb 6, 2019 | 08:58 PM
  #662
pwpacp's Avatar
That is the best way to dry 'em off....or at least the most fun!
Old Feb 6, 2019 | 09:05 PM
  #663
Rick'sJag's Avatar
Originally Posted by wrair
NOPE... incorrect. Just to be sure, I checked again with Michelin. For the XK, and my Michelin tires that are not directional, Michelin recommends side to side rotation. Now that is not the case for my directional M&S Michelins on another car.
Good Luck, and PLEASE let us know how you make out with side to side rotation
Old Feb 6, 2019 | 09:09 PM
  #664
pwpacp's Avatar
Which Michelins are you running?
Old Feb 7, 2019 | 12:26 AM
  #665
wrair's Avatar
Default Rotation
AS/3 on 19 rims for my 2010 XK Jag and Michelin X Ice for the Buick, the bad weather auto.
I'll be sure to let the forum know of any problems! I did not have to rebalance the wheels, on either auto.
best,
Old Feb 11, 2019 | 06:12 PM
  #666
MarkyUK's Avatar
Actually last week, but no time to take pics until today
Fitted A DTUK power control and pedal box.
Makes a world of difference to pedal response and power delivery, next will be a dyno to see if it's made a difference
Tuning box is supposed to give 25PS and 48 ft/lbs torque
https://www.diesel-performance.co.uk/
Yes i do have a before dyno and chose the power box over an ecu flash as
1) Our cars are notoriously hard to tune
2) It can't be overwritten
3) I couldn't find a single poor review of their products (lots on poor tunes though)
4) The German equivalent is TUV approved
5) I can swap it to another car for a small reprogramming charge
Money well spent IMO
I am running it in it's lowest settings on both and my normal drive to work usually delivers 22mpg UK (18.2 US) but since fitting have been getting 26mpg/21.5 but that just might be the electronics fooling the ECU!?
Old Feb 11, 2019 | 06:23 PM
  #667
JaguarJeffrey's Avatar
Oil change and brake system flush. Brake pedal still seems to have a bit of play in it before the brakes kick in, so I am taking it back to the dealer tomorrow to have them determine if there is an additional issue with the brakes or if I am just mentally comparing it to my XJL.
Old Feb 11, 2019 | 11:28 PM
  #668
u102768's Avatar
Fixed the glovebox damper on my '10 XKR.
Old Feb 12, 2019 | 02:27 PM
  #669
makecopies's Avatar
Water pump
Old Feb 12, 2019 | 02:39 PM
  #670
110reef's Avatar
Originally Posted by makecopies
Water pump
Proactive or failure?
Old Feb 12, 2019 | 02:47 PM
  #671
makecopies's Avatar
Proactive after the valley pipes and the thermostat housing was changed there was a slight spot of steam that would come out of the front grille after a long trip
not bad considering I have gotten more than 100k miles out of them!
Old Mar 1, 2019 | 07:10 PM
  #672
Ngarara's Avatar
Fitted my BlackVue DR900S-2CH dashcam - just the front & rear cameras for now, battery pack comes later...
Surprisingly, I had no trouble tucking the cable runs behind the roof panels; there's currently a coil of spare cable on the rear parcel shelf, but I'll sort that out another day.
Old Mar 2, 2019 | 02:10 PM
  #673
Aonsaithya's Avatar
I had a heated steering wheel retrofitted, along with aluminium shift paddles (T2R6547MMU). The new paddles seem to have a shorter, firmer action, and feel more "accurate". On the other hand, being aluminium, they feel quite cold...
Can you show where you put the rear camera? Inner roof, rear glass (defroster wires?)?
Old Mar 2, 2019 | 03:13 PM
  #674
britannia's Avatar
PeterV8,
There is a Jag service bullletin (JTB 00047) regarding XK Puddle Lights not working. It involves the CCF file..............I have always had non working PL since I bought car in 2011. Only Jag dealer can change this file and since I don't drive at night never bothered fixing them!!
Hope this info helps,
Cheers, Adrian Brennan
Old Mar 3, 2019 | 11:38 PM
  #675
Simon Tan's Avatar
Performed a spoiler augmentation on my car this weekend after lucking upon a perfectly color-matched donor part from this poor prematurely departed XK.
Old Mar 4, 2019 | 12:10 AM
  #676
Cee Jay's Avatar
So no problems with the install I guess?
Are you happy with the results?
Old Mar 4, 2019 | 12:43 AM
  #677
Simon Tan's Avatar
Install was pretty straightforward other than having to solder my old antenna connector on since the junkyard snipped it. But I can't complain given the deal I got. Ended up getting it for $160 after pointing out what looked like some warping in the Ebay pics. Turned out to be nothing, and the paint is perfect (poor donor car only had 13k miles).
Like you said in the other post, once it's on, you wonder why Jag even bothered with the original spoiler. It's another one of these little mods that's probably imperceptible to most (asked my family if they noticed anything different, and they had no idea what I did), but it's a big difference to my eyes.
Old Mar 4, 2019 | 06:37 AM
  #678
pwpacp's Avatar
Sometimes it is just a case of looking for the right part at the right time! A great mod in my book.
Old Mar 4, 2019 | 12:37 PM
  #679
Ngarara's Avatar
On the glass, at the top, slightly to the left of centre because there's a manufacturer's logo & safety mark right in the middle. I tried to arrange it so that the centre of the lens is between two wires, but to be honest, they are so close to the lens that they are effectively invisible. The image from the rear camera looks fine.
Old Mar 4, 2019 | 03:35 PM
  #680
Aonsaithya's Avatar
Ok, glass is probably the best/only reasonable mounting place. I'm worried about sticking adhesive over the defroster lines, unless the camera contact patch is small enough to go between them? I reckon they'd get quite hot?
