What did you do to your X150 today?
Old Jun 25, 2020 | 09:28 AM
  #1281
Malawi's Avatar
Originally Posted by De5in
It's a 5.0l XK. I will be getting the tune from AlexJag. I will write it up exhaustingly and ad naseum I assure you.
interested to hear your thoughts
Old Jun 25, 2020 | 09:56 AM
  #1282
Malawi's Avatar
Default changing lights to LED
headlights: changed the side marker, side lamp and cornering lamp to LED. waiting for 6000K new halogen bulbs for main light. I thought of going LED but too much work dealing with the balast etc. New HID bulbs are much better than 10 years ago.
Added a brake and turn signal LED to rear diffuser. looks superfly.
changed rear turn signal lights to LED. no resistor needed but it took a while to find good LEDs that would fit without hyperflash and bulb error.
left signal is LED so u can compare
replaced 3 bulbs to LED. got rid of the orange side marker bulb
diffuser LED
strobe brake LED light on right
now working on rear brake/running to install strobe LEDs. when u hit the brakes, the lights flashes 3 times then go solid. having bulb error issues with this light (P21/5W). installed resistors but problem not going away.
Old Jun 25, 2020 | 10:02 AM
  #1283
Malawi's Avatar
Default Trying to fix rear spoiler LED brake light for cheap
work in progress. took the light apart. waiting for LED replacement light delivery
Old Jun 25, 2020 | 10:23 AM
  #1284
Malawi's Avatar
Default installed new front LED fog lights
My prior LED burnt out after 3 years
full beam
daylight running
Old Jun 25, 2020 | 02:13 PM
  #1285
kj07xk's Avatar
Originally Posted by Malawi
daylight running
What did you wire the DRL to?
Old Jun 26, 2020 | 12:46 AM
  #1286
Malawi's Avatar
used a fuse tap.
Old Jun 28, 2020 | 11:24 PM
  #1287
DannyJ's Avatar
full beam
daylight running
Do you have a link to the DRL enabled fog lights?
Old Jun 29, 2020 | 08:41 AM
  #1288
steve_k_xk's Avatar
De-clouded my lens , repaired the two broken wires for the headlight solenoid and re insulated well over a dozen wires.
Old Jun 29, 2020 | 09:24 AM
  #1289
Sean W's Avatar
Steve, what was the re-insulation process? Are we talking shrink wrap over the repaired wires, plastidip, electrical tape or did you do something else?
Old Jun 29, 2020 | 05:34 PM
  #1290
steve_k_xk's Avatar
I had no shrink wrap available as it was too late to get some , so electrical tape it was .
My soul intentions was to simply de cloud my headlight lenses as vision was extremely poor , I had no idea that when I opened it up the wiring would be in such poor condition.
Old Jul 2, 2020 | 06:49 AM
  #1291
Marco75's Avatar
Finally found a set of Takoba wheels for my Portfolio... had them refinished and installed.
Old Jul 3, 2020 | 03:56 AM
  #1292
Laird Ravenscraig's Avatar
Default Fixing the Glovebox Damper
Hi!
Today I fixed my glovebox Damper.
Worktime just 1 hour.
Now the Glovebox opens smooth....
Screw to remove
Another two in the Box
Screw above the Power Socket
Another below the Box
Glovebox
Fixed it with a cable tie
Old Jul 3, 2020 | 06:16 AM
  #1293
barnsie's Avatar
Great pics! Thanks for sharing.
Old Jul 3, 2020 | 06:22 AM
  #1294
kj07xk's Avatar
Easy alternative to drilling a small hole and using a small bolt or cotter pin. Nice.
Old Jul 4, 2020 | 04:10 PM
  #1295
JackJohn's Avatar
Old Jul 4, 2020 | 06:14 PM
  #1296
Paulo Sérgio's Avatar
Upper control arms replaced? any reason for that?
Old Jul 6, 2020 | 07:01 PM
  #1297
JackJohn's Avatar
This weekend was a good one for the Jag. First, the battery was replaced, would not start on Thursday, put it on a 10a charger overnight, still wouldn't start on Friday. Purchased new battery and replaced it. Old battery was dated 10/2014 so it was time. Then over Saturday/Sunday we replaced the rotors with drilled and grooved ones from Stoptech and all new pads from Stoptech. Painted the rotors and put on new decals.
Old Jul 9, 2020 | 05:20 PM
  #1298
vintageyz's Avatar
These are shots of my wheel change. I purchased the 20" Sentas damaged. A large crack in one and scuffs on all. Turned out there was more damage as the work went on. The repairs turned out great and the powder coat completed. I also did a ceramic coating on the all the wheels exterior and interiro. Now looking at a refurb of the wheel bolts and detailing on the wheel/tire combo.
Old Jul 12, 2020 | 12:58 PM
  #1299
peterv8's Avatar
Finally got the time for a polish! :-)
Used Sonax rubbing compound with green pad on my polisher, then Sonax polish with blue pad and last Sonax Hardwax with black pad! Happy with the result! :-)
Old Jul 12, 2020 | 04:37 PM
  #1300
V7Sport's Avatar
Looks awesome😎
