What did you do to your X150 today?
Old Nov 25, 2020 | 10:26 AM
  #1461
Cee Jay's Avatar
Several seconds is quite long enough, and if there IS a spark, I've never seen it.
Old Nov 25, 2020 | 11:41 AM
  #1462
Sean W's Avatar
Originally Posted by wsn03
Thank you to everyone for your replies.
Q 1. How long do you hold the wires together
Q2. Is it a big sparks show?
per the posting 120 seconds. you are just touching two cables both disconnected from the battery so no spark
Old Nov 25, 2020 | 12:12 PM
  #1463
wsn03's Avatar
Originally Posted by Sean W
Quite simple actually. Our system has multiple modules and multiple capacitors. Holding the cables together allows to capacitors to discharge, thereby resetting.
From the electrical training manual:NOTE: A hard reset does not repair a fault condition. It simply brings all control modules back to their baseline condition. If a hard reset eliminates the symptoms, then further diagnosis is needed to determine the cause of the conditions, i.e. low battery causing a single control mod- ule to come off line temporarily.
Hard Reset Instructions
A ‘hard reset’ restores the control modules to their base conditions assuring that network communications are synchronized.
CAUTION:
Be sure to retrieve DTCs before disconnecting the battery.
All Vehicles except X105, X150
  • Disconnect the negative cable of the battery for at least 120 seconds
  • Reconnect the battery negative cable
  • Perform window initialization
    X105, X150 Vehicles
    Due to the window drop entry feature, the following pro- cedure should be followed to prevent door seal damage.
  • Open one window fully or open a door
  • Reset the window position memory for the passenger and driver door windows
    NOTE: If a hard reset is performed on a vehicle with a sunroof / roof opening panel and the roof is open at the time of the hard reset, the sunroof initialization proce- dure must be performed.
sorry im being thick again but this is just removing the negative cable, not joining the 2 together. Really interested to know why the difference, which is right or do both achieve the same thing?
Old Nov 25, 2020 | 12:30 PM
  #1464
Cee Jay's Avatar
Modules contain capacitors, capacitors hold electrons.
Disconnecting a battery will cause capacitors to slowly discharge, resetting volatile memory........ eventually.
Shorting a positive lead to ground will actively discharge capacitors, resetting volatile memory, but this will happen nearly instantly.
Therefore, EITHER disconnect the battery for many minutes, or touch the two DISCONNECTED battery leads, the Positive Lead and the Negative Lead, together for a few seconds.
MAKE SURE there is NO connection between the battery's + and - posts!
Old Nov 25, 2020 | 01:30 PM
  #1465
wsn03's Avatar
Got it, very much appreciate the patience and the informed answer. Thank you
Old Nov 25, 2020 | 02:16 PM
  #1466
007XKR's Avatar
I haven't seen a spark, but I did this a couple of weeks ago and heard what sounded like a spark, more like popping a breaker actually. Since then, my TPMS warning has gone away and not come on again.
Old Nov 25, 2020 | 04:11 PM
  #1467
mhminnich's Avatar
Default Refinished headlights
Took some time on a gorgeous fall afternoon to refinish the headlights.
Wet sanded with 2500 then used the 'rag and spar varnish' technique to recoat them. I'm very pleased with the results.
Before
After
Old Nov 25, 2020 | 04:25 PM
  #1468
V7Sport's Avatar
1. A few (10) seconds
2. No, unless you forgot to disconnect at least one of the cables from its respective battery terminal💥🙀
Old Nov 26, 2020 | 03:00 AM
  #1469
wsn03's Avatar
Before
After
Do you flat off the outside of the lense I presume? Ive not taken one apart so don't know if it comes apart.
Old Nov 26, 2020 | 03:34 AM
  #1470
MarkyUK's Avatar
Had winter tyres and (newly ceramic sealed) Vulcans fitted, just in time as 4c outside.
As they took my Summer vortex's off I asked for 2 mins with the wheel oft to clean shocks and arms with g101 cleaner, then sprayed everything with bilt hamber atom-mac.
Will take a few miles to break in new tyres but could tell the difference in rhe 2 mile drive back with 8mm of tread. Oh, winter tyres running 3psi higher due to softer compound
Old Nov 26, 2020 | 04:26 AM
  #1471
neilr's Avatar
I'm not sure I follow the logic. More pressure than recommended (over inflation) will still still mean that the tyre is running more on the central part than it is designed for regardless of rubber characteristics, resulting in less rubber on the road and faster central tyre wear. Does your handbook/door plate suggest to use more pressure for winter tyres? I don't remember seeing such a recommendation in the 25 years I have been using winter tyres.
Old Nov 26, 2020 | 07:26 AM
  #1472
Bill Mack's Avatar
wsn03, sorry I don't understand your question.
"England and America are two countries separated by the same langauge."
Attributed to G.B. Shaw
Old Nov 26, 2020 | 08:25 AM
  #1473
mhminnich's Avatar
I refinished the outer lense on the car. No disassembly.
Old Nov 26, 2020 | 08:46 AM
  #1474
jons's Avatar
technically he didn't say overinflate, he just said 3psi relative to his usual figure. both figures could be just below spec.
since winter tires are both a slightly softer compound and the tread is cut taller (and a little differently), overinflating in theory should put back a tiny bit of the mechanical grip that you very reasonably give up when you go from summer to winter tires, and only in the center band as you've stated. but of course that's holding all else equal, which means, both tires he uses would have to be rated the same, and the same size exactly, and so on: i'm not sure you would be able to just add pressure to a totally different radius/aspect/etc. tire and get any effect out of it. but you might experiment until you do observe one, and then decide on 3psi or so to reproduce it regularly.
and you're right that no manual would ever recommend it, but then, plenty of manuals are written by the lawyers instead of the engineers.
Old Nov 26, 2020 | 09:00 AM
  #1475
wsn03's Avatar
Thank you. Mine seem to be perfect, but its really interesting to know I can use 2500 on glass like that - every day's a school day
Old Nov 26, 2020 | 09:03 AM
  #1476
wsn03's Avatar
Ha!
Sorry - in plain speak I'm asking if he does the inside or outside of the glass unit with his wet and dry 2500 grade (if that makes sense)
Old Nov 26, 2020 | 09:32 AM
  #1477
XKR416's Avatar
Default Added MINA HOOD LOUVERS
A
Old Nov 26, 2020 | 09:35 AM
  #1478
Sean W's Avatar
Ha!
outside.
Old Nov 26, 2020 | 10:06 AM
  #1479
Bill Mack's Avatar
Getting to the inside of the headlight cover (which is plastic) is a little more complicated.
I've not done this myself, but I understand you need to remove the headlight assembly and then separate the cover from the headlight body. There is a butyl rubber sealant holding the two pieces together and this needs to be heated in an oven or other enclosed space using a heat source (heat gun, e.g.) to be pliable enough. There are also spring clips that need to be removed. Some care is required in these steps. Overheating the plastic parts can cause melting and the butyl rubber can mar the surface of the bright parts in the headlight itself. On reassembly you need to add some butyl rubber to make up for that lost in disassembly, clamp cover and headlight together and reheat to ensure a tight and complete bond.
Others here have done this work but I did not find a good thread to link to. However, this is a very detailed video that I think is helpful.
Once you have the cover separated, you can work on the inside in the same way you would work on the outside (several threads here on this) but of course you don't need to coat the inside with an anti-UV coating.
Old Nov 26, 2020 | 10:16 AM
  #1480
XKR416's Avatar
Default Installed Mina Louvers
