will not start
Old Mar 3, 2018 | 12:31 PM
ssteveb63's Avatar
Default will not start
2007 xk convertible. Error message "cannot engage parking brake". Had battery checked, all ok. Tested motor that engages parking brake, it works. Ordered module on-line, replaced it, still same result.
Old Mar 3, 2018 | 12:52 PM
JagV8's Avatar
Still sounds like a weak battery - or weak power to the module/motor.
Or the (Bowden) cables are not moving freely.
Old Mar 3, 2018 | 01:09 PM
NBCat's Avatar
+1 on weak battery.
What is the voltage across the terminals with the ignition in the off position?
Old Mar 3, 2018 | 01:13 PM
ssteveb63's Avatar
Had battery store check it, they said it has 12.6v and 900 cca. I metered it this morning and has 12.6 v
Old Mar 3, 2018 | 01:16 PM
ssteveb63's Avatar
Don't know about Bowden cables. Put car in neutral, engaged parking brake(manually with 12v power supply), car won't move. Disengaged parking brake, car moves freely.
Old Mar 3, 2018 | 02:02 PM
Welcome to the forum ssteveb63,
I'm not absolutely certain about the issue here. Your thread title is will not start but your text is cannot engage parking brake.
There are so many error codes for the parking brake system that troubleshooting a fault is complete guesswork without a scantool that can read C codes.
When you get a minute, please follow this link New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum to the New Member Area - Intro a MUST forum and post some information about yourself and your vehicle for all members to see. In return you'll get a proper welcome and some useful advice about posting to the forum.
Old Mar 3, 2018 | 02:48 PM
ssteveb63's Avatar
Thanks GGG, took care of that, very informative and helpful. The car will not start apparently because it cannot engage the electronic parking brake. May have to have it towed to dealer, but I am trying to fix it myself, if possible.
Old Mar 3, 2018 | 02:53 PM
NBCat's Avatar
Have you attempted a reset of the systems by disconnecting both battery terminals and then touching them together for ten seconds?
Also, are there any DTCs stored?
Old Mar 3, 2018 | 02:59 PM
ssteveb63's Avatar
I have disconnected both battery terminals and touched them together for at least 20 seconds. What are DTCs?
Old Mar 3, 2018 | 03:03 PM
peterv8's Avatar
You shouldn't need to engage the parking brake to start the car, just press the brake pedal!? Strange you can't start the car with no hand brake? Maybe it's the Button that's broke?
Old Mar 3, 2018 | 03:14 PM
ssteveb63's Avatar
From what I have read, the car engages the electronic parking brake when you put it in park. I can manually engage and disengage it with a 12v power supply. The car is not "seeing" it engaged. I have replaced the module that controls it, but no luck.
Old Mar 3, 2018 | 03:23 PM
Ranchero50's Avatar
Hey Steve, download the free tech manuals in the stickies at the top of the sub forum. You'll want the X150 service manual and the wiring diagram for your serial number range. The tech manual is actually pretty darned good and should help a lot.
Sound like you have a sensor problem. I'm not certain how the actuator works but from what I learned while doing the rear brakes, the actuator has a sensor to know if it's pulling correctly. It needs reset when you replace the rear pads. I assume it's almost too smart for it's own good. I am surprised about your comment that it's putting the brake on in park. I can hear mine pull in and never noticed it in park. Just the park pawl in the transmission engaging is all I ever hear.
Old Mar 3, 2018 | 03:28 PM
ssteveb63's Avatar
Thanks Ranchero50, I'll take a look
Old Mar 3, 2018 | 05:36 PM
From what I have read, the car engages the electronic parking brake when you put it in park. .....
NO - the parking brake RELEASES automatically when you move the selector from P or drive away but it has to be ENGAGED manually.
Where did you read that?
Old Mar 3, 2018 | 05:45 PM
NBCat's Avatar
...What are DTCs?
Diagnostic Trouble Codes. When they set, the MIL (Malfunction Indicator Light also referred to as the 'check-engine-light') is turned on.
Use the OBD port to access any stored codes. If there are any, post them here.
+1 on obtaining the Workshop Manual and other information from this forum.
Old Mar 3, 2018 | 05:48 PM
ssteveb63's Avatar
Thanks GGG, I may have explained it wrong. Don't remember where I read that, this problem occurred a couple of months ago. I've been researching possible causes and how to fix it since then. Car still will not turn over with good battery. Error message says "cannot engage parking brake"
Old Mar 3, 2018 | 05:51 PM
ssteveb63's Avatar
NBCat does that mean I have to go buy a diagnostic tool?
Old Mar 3, 2018 | 05:56 PM
NBCat's Avatar
https://www.ebay.com/itm/ELM327-v1-5...oAAOSw~y9ZCFa3
Download the Torque Pro app and pair your smart phone with the Elm device via Bluetooth.
Old Mar 3, 2018 | 06:02 PM
ssteveb63's Avatar
Done, won't be here until 3/12. Any additional advise would be greatly appreciated.
Old Mar 3, 2018 | 06:32 PM
tberg's Avatar
Sounds like a brake switch. If it's faulty, it will not allow you to start the car. Have you stepped on the brake so hard that you think you're going to break it? Try that and push the start button.
