XK top won't go down or up
Old Jan 24, 2019 | 07:44 PM
dcar172387's Avatar
Default XK top won't go down or up
My top isn’t working. My mechanic says that the switches in the top harness are shot. He’s been trying to find a salvage harness for months with no luck. New it costs $3000+. Anyone have an idea where to find one? Mine is a 2007 XK. Also isn’t there any easy way to work the top manually? It’s prime convertible weather in Florida.
Old Jan 24, 2019 | 07:57 PM
jagtoes's Avatar
The procedure to lower the top manually is in the owners manual. How does your mechanic know that the switches or harness is bad. Did he read the OBDII codes for the top. Also what is the status of your battery. Is it fully charged and reading 12.6 volts. What happens when you press the top button to lower. Do you hear anything running. Do your windows go down or are there any messages in the dash about the top. When did it stop working .
Old Jan 24, 2019 | 08:00 PM
WhiteXKR's Avatar
Have you tried to manually reset the top? See your owner's manual.
If that does not work get another opinion from a Jaguar specialist. Your mechanic's description does not make much sense. A defective switch can be replaced individually. Why replace an entire wiring harness? It sounds like he is guessing.
Old Jan 24, 2019 | 09:13 PM
pwpacp's Avatar
More information is needed to help. List the exact conditions and indications including if the engine is running while attempting to cycle it. Complete wire harness failure is more than far fetched as a cause IMHO. Another point, what were the conditions when the top stopped opperation?
Old Jan 25, 2019 | 05:23 AM
envincibal's Avatar
I just recently had an issue where the top wouldn't go fully up or down, and not drive-able in those positions (and I'm heading to my new home in Florida tonight!). Turns out the issue was my battery voltage was a bit too low; put it on my C-Tek overnight and the next day, bam! I'm back in business and thinking about the sunshine state :-)
Old Jan 26, 2019 | 03:27 PM
PsiFox's Avatar
sometimes if the battery is on the way out even a ctek can’t hack it. On mine the computer was shutting down systems, roof first, to keep enough juice to start the car.
New battery solved it.
Old Jan 27, 2019 | 09:48 AM
dcar172387's Avatar
My battery is at 13.4. The rear windows work but nothing else. When I press the button to move the top up or down, there is no sound save for the windows. As far as trying to work the top manually, it only goes down partially then there’s resistance and yes, I did turn the “bolt” one full rotation counterclockwise on the pump.
I think that I’m just going to give and go to my local Jag dealer to figure this out.
Old Jan 27, 2019 | 07:51 PM
WhiteXKR's Avatar
If you give the manual reset another try, wait 20-30 minutes after rotating the bolt on the pump to allow for the system to depressurize. The top should move freely after the wait.
Old Jan 28, 2019 | 03:59 PM
PsiFox's Avatar
Just another thought
the luggage separator is installed in the correct position?
if it isn’t the rear windows will work but nothing else.
also it’s not unknown for the magnet to fall off the separator thus stopping the roof from operating but again letting the rear windows work.
jagtoes
Aug 6, 2018 05:20 PM
95XJSconv
Jul 25, 2014 02:16 PM
Bertram Wooster
May 1, 2012 09:01 PM
rsigue
Apr 6, 2011 06:06 PM
pu5hkar
May 26, 2009 03:28 PM
