XKR suddenly got dymanic mode fault
Old Feb 16, 2026 | 05:50 AM
Belsy23's Avatar
Default XKR suddenly got dymanic mode fault
I have an XKR. I put in dynamic mode a lot as the exhaust sounds better. It turns on but after a minute or so it turns off and says dynamic mode fault. Also the paddles won’t work which I assume is connected. When I switch the engine off. It resets and it will come on but switches off again soon after.
Old Feb 16, 2026 | 08:49 AM
Stuart S's Avatar
What year? What are the DTCs? Make sure your battery is fully charged.
Old Feb 16, 2026 | 10:49 AM
Belsy23's Avatar
Default 2011
Hi Stuart.
it’s a 2011 with many 2012 upgraded parts. Dymanic was fine but suddenly stopped on Saturday. Starts up and it will switch on but then turns off saying fault. Also paddles can’t be used. Battery seems ok. Not sure how to make sure it’s 100 % ?
Old Feb 16, 2026 | 11:29 AM
Stuart S's Avatar
Battery should read at least 12.6 volts after sitting overnight and before you start the engine. A weak battery will cause all sorts of electrical gremlins.
Search this Forum for how to do a hard reset. That clears the volatile memory in several modules and resets them to factory defaults.
If your XKR is not your daily driver, I recommend that you keep it on a battery maintainer (not a trickle charger). See:
https://www.jaguarforums.com/forum/x...argers-283411/
Stuart
Old Feb 17, 2026 | 11:42 AM
Belsy23's Avatar
Default I had a steering wheel re fit day before
Hi Stuart. Just realised. I had a steering wheel refit the day before in new two tone leather. Then next day the dynamic doesn’t work and neither do the paddles. ! I’m thinking this must be the issue ?
Old Feb 17, 2026 | 04:05 PM
kj07xk's Avatar
Ok, that’s new info! Yep, go back to the fitter, they messed it up.
Old Feb 23, 2026 | 09:28 AM
luv2fly's Avatar
@Belsy23 If you don't need the exhaust to ever be in quiet mode, and I don't know why you would as these cars are not loud, you can remove fuse 19 I believe between the rear seats or disconnect the vacuum actuators on the exhaust and plug the lines. I unplugged mine and while I was in the LR wheel well disconnected and removed the vacuum pump. Because...... weight reduction.
Old Feb 23, 2026 | 10:03 AM
Belsy23's Avatar
Default Thanks. Yes I heard this. The fault was corrected
I had a wheel re trim and he had not plugged on wire back in that controlled the dynamic and paddles. All ok now. It’s is loud to be fair I think it’s a different exhaust and it was tuned to 593 BHP ! But does sound slightly better with dynamic on.
Old Feb 23, 2026 | 11:15 AM
kj07xk's Avatar
PM sent.
UltraBlackXKR-S
Dec 30, 2024 11:31 AM
XKDreams
Jun 12, 2024 04:31 AM
Mike V
Jul 11, 2019 02:25 AM
thelongwayhome
Apr 29, 2018 03:19 PM
powerhouse
Apr 25, 2018 06:30 PM
