XK120 XK140 XK150 1948 - 1962
Changing 'earth'
Old Sep 10, 2021 | 12:07 PM
BruceH's Avatar
Default Changing 'earth'
I recently acquired a '57 140. It has a brand new battery and brand new battery cables (and a brand new coil) wired negative ground. IF I convert it back to positive ground, do I need to do anything else, other than switching coil leads ? I will not have a radio or audio system.
Old Sep 10, 2021 | 02:12 PM
Coventry Foundation's Avatar
Fuel pump and Clock!
Old Sep 15, 2021 | 06:06 PM
Fraser Mitchell's Avatar
The question is - why would you want to convert back to positive ground ?
Old Sep 19, 2021 | 04:47 PM
BruceH's Avatar
Why - good question actually. That's the way Bill Lyon designed it; the clock and fuel gauge don't work; the car will live in a humid environment other negative ground vehicles are always having electrical connection problems. But then the change might become a can of worms, but then again the car is intended to be a driver, not a show car so originality doesn't matter. Maybe making the gas gauge work is the primary consideration, but the polarity switch may or may not be the answer to the problem Life is never simple !
Bruce
Old Sep 20, 2021 | 03:11 AM
Bruce
Reason I asked was because when I rebuilt a Mark 2 in the 80s, it was at a garage owned by an auto-electrician who worked at Lucas. It was he who advised me to convert to negative earth. Actually it wasn't William Lyons who designed it this way, it was engineers at Lucas, Jaguar just installed what they provided like most of the British car industry at the time. There was a reason for positive earth, but I've forgotten what it was.
Unfortunately it is so long ago I can't remember the details of the changeover to negative earth, but all the instruments worked afterwards.
Old Sep 20, 2021 | 03:15 AM
I found this: -
https://mgaguru.com/mgtech/electric/et098.htm
Old Sep 20, 2021 | 10:49 AM
BruceH's Avatar
According to Wikipedia, the way electrons flow, Positive Earth promotes corrosion of the bodywork, the 'earth' side; Negative Earth promotes corrosion of the electrical connections. 'Yo pays yo money and takes yo choice' since I see that the fuel guage is based on electrical wiring, not using tank body as one connection, the gauge readings should be independent of the 'earth', and besides I just tested the petrol gauge itself and it came out bad. I'm now strongly motivated to just leave the wiring alone.
Bruce
Old Sep 21, 2021 | 11:58 AM
sil9090's Avatar
Default Changing earth
if you revert to positive earth you will need to replace the alternator as they only function with negative earth system.Originally positive earth systems were employed because the electron flow was believed to slow down the rusting out of the steel used in production.Why would you want to step backwards in respect to dynamos versus alternator?
Old Sep 21, 2021 | 12:59 PM
BruceH's Avatar
Good points, but this car still has a generator, not an alternator, and I am more concerned about corrosion on electrical connections than bodywork. That being said, I think I am going to leave well enough alone and keep things the way they are. After EXTENSIVE work on the SUs it now starts and runs great. Hope to have new (vice 15 year old) tires on it by this weekend. Then I can really take it for a drive !
Bruce
Old Sep 21, 2021 | 01:19 PM
Bruce
Enjoy your ride !
What brakes are on it ? 120s were renowned for brake fade, and it wasn't until the 150 with discs that the problem was finally put to bed.
Old Sep 21, 2021 | 01:59 PM
sil9090's Avatar
Hi Bruce
nice to hear you have it running ,enjoy.
Old Sep 22, 2021 | 12:23 PM
BruceH's Avatar
Stock drums, not sure about the linings. In flat Kansas, USA, not yet seen any sign of fade.
Old Sep 22, 2021 | 12:26 PM
BruceH's Avatar
Started, not well but OK this morning, at 50 degrees F, with cold-start carb still disconnected. Cold-Start problems clearly eliminated.
Old Sep 22, 2021 | 03:27 PM
Modern brake linings may be a lot better, but having read the chapter on the XK sportscars in Paul Skilleters book on the Jaguar sports cars, it is clear that the fade came suddenly. One road tester admitted to having bad dreams afterwards when it happened to him ! Of course on the empty UK roads of the very late 40s and early 50s it was possible to drive very fast and get away with it on normal roads.
British_Atlantic
Jan 7, 2021 11:40 AM
SovietB3
Feb 9, 2020 12:48 PM
Mark Bialzik
Jul 3, 2018 07:08 PM
al_roethlisberger
Feb 9, 2015 04:48 PM
petem1957
XJ40 ( XJ81 )
Nov 20, 2007 05:15 PM
