06 XKR Victory Edition - front suspension
Old Apr 11, 2015 | 12:19 PM
06victorybw's Avatar
Default 06 XKR Victory Edition - front suspension
Front suspension clunks and feel sloppy over bumps, only 45K miles, has gotten very bad in the last year.
Old Apr 11, 2015 | 01:54 PM
Welcome to the forum 06victorybw,
I've moved your question from General Tech Help to XK8/XKR forum. Members here with the same model will be able to help.
Old Apr 11, 2015 | 02:18 PM
cjd777's Avatar
Check your front shock towers, under the black cover. If it has what looks like a crumbing sponge and the bolt not centered, you have bad shock mounts. Lots of information in the DIY area at the top of this forum about that. Not unlike most strut systems in todays cars. Your shocks may be good, but the bushings are a weak area here and replacing is only a few dollars more than the bushing, go figure.
Wayne
Old Apr 11, 2015 | 03:03 PM
Jon89's Avatar
^^ What Wayne said....
Old Apr 11, 2015 | 05:48 PM
Looks like crumbling sponges to me, easily crumbles with my finger looks like a great place to start. Thanks again.
Old Apr 12, 2015 | 06:05 AM
SteveJacks's Avatar
While you have it apart, replace the upper control arm bushings, they are soft rubber and don't last all that long, consider Powerflex ploy bushes. Also, replace the sway bar bushings. The end links generally last well, but the sway bar bushings themselves don't.
Old Apr 12, 2015 | 12:30 PM
Appreciate the advice, need to get it right if its coming apart
Old Apr 12, 2015 | 04:18 PM
SteveJacks's Avatar
Yes, I did piecemeal, not replacing all at the same time. Wish I had just done it all at once. But I got really good at it. Turns out none of this stuff really is all that difficult, worst is compressing the springs to get the top shock mount off. Borrow a decent compressor from the autoparts store, one that has the safety locking pins, otherwise the thing will slip off. I had a set of my own without locking pins, then went and borrowed a decent spring compressor from Napa. i also recommend getting a shock nut socket tool, it is a special machined peice that holds the shock threaded rod from the top and allows a deep angle box end over it to remove the nut (and tighten) the tool is avaialbe at most autoparts stores for around $10 if you don't have one. I couldn't tighten the nut enough on my new shocks without it. I also had replaced my upper control arm bushings with OEM bushings, but shortly after I changed them out with the Powerflex poly bushings and the difference was noticeable. The OEM rubber is just too flexible for me...that's my opinion, not shared with everyone though.
Old Apr 12, 2015 | 09:45 PM
Steve, thanks for your input, I have been online looking at the parts and repair process.
FrickenJag
Jun 16, 2025 02:15 PM
GordoCatCar
Jan 2, 2017 01:10 PM
Skeeter
Sep 17, 2015 08:15 PM
obwoodie
Sep 3, 2015 07:45 PM
arnoldmilk
Sep 3, 2015 07:42 PM
