Which 18" Wheels Will Clear Brembo Calipers?
Old Sep 5, 2019 | 07:08 AM
crtfour's Avatar
Default Which 18" Wheels Will Clear Brembo Calipers?
Good Morning,
On my 2002 XKR, I have replaced the original double five wheels with some 20" BBS wheels. Therefore my existing spare will no longer work if needed and what I would like to do is find a used 18" wheel to use as a spare and then find a decent tire. The double five's will not clear the Brembo calipers but from what I understand other ones will (but not sure which). Another option is finding one of the orange donut spares, but I think these would likely have an old tire on them.
Thanks for any suggestions.
Rob
Old Sep 5, 2019 | 09:11 AM
fmertz's Avatar
Pretty sure the Hydra wheels would work. Not sure about the similar-looking Ares/Aris/Arris.
Old Sep 5, 2019 | 10:16 AM
Higgins's Avatar
The spare tire is not occupying much space, but a Hydra wheel will. Will you be able to fit the lid over the spare wheel in the boot? I doubt it
After fitting brembos at my Xkr I simply removed the spare tire saving weight
Old Sep 5, 2019 | 04:33 PM
ccfulton's Avatar
Why not a space saver spare tire? My XKR has Brembo brakes and came with a factory donut spare tire in the boot.
Old Apr 10, 2025 | 07:16 AM
Szabadi Kalman's Avatar
1. Yes 18" Hydra (14spoke) is working with the 355 brembo discs and big brembo calipers up front without problem !
This attached photos is a good example : 2003 XKR convertible - with 18" Hydra wheels + Brembo big brakes
Old Apr 10, 2025 | 12:08 PM
Kuddlesworth's Avatar
I run Hydra wheels on my XKR with brembo brakes. They where sold as the winter set I think or something like that. I had the 20" detroit wheels on before but I wanted to go to larger sidewalls, frankly the car handles the same but it's more comfortable and the tyres are much cheaper and last longer then 1-2 years.
Old Apr 10, 2025 | 10:30 PM
brinny's Avatar
Why would you want an 18" spare if the other 3 would be 20".?
Old Apr 16, 2025 | 07:30 PM
johns55's Avatar
Double five's should clear Brembo calipers.
Old Apr 17, 2025 | 11:21 AM
chilly's Avatar
Milans fit too.
Old Apr 17, 2025 | 12:42 PM
Higgins's Avatar
Double fives needs a spacer to clear the big brembo calipers up front
X308R
Mar 17, 2016 03:08 PM
oldmots
Dec 21, 2011 08:55 AM
shl1980
Jan 8, 2011 04:57 AM
Fairlane500
Jun 26, 2009 05:34 PM
