1998 o/s front lower ball joint dust cover split
Old Jul 5, 2014 | 01:54 AM
louismacrides's Avatar
Default 1998 o/s front lower ball joint dust cover split
Hello my 1998 xk8 failed her mot on 2 things ,,,wish bone front bush and lower ball joint boot split,,,,,do I have to dismantle things to lift ball joint out and replace rubber boot (the ball joint itself is fine)can I just unbolt split joint with ball joint splitter and jack it up replace boot,thanks all
Old Jul 5, 2014 | 06:41 AM
I've moved your post to the XK8/XKR section where members with the same model will best be able to assist .
regards,
steve
Old Jul 5, 2014 | 06:20 PM
cjd777's Avatar
Default ball joint
Louis, you are right on the ball joint boot, but the bushing will be a bit of a moan.
Wayne
Old Jul 6, 2014 | 03:38 PM
Wayne
thankyou ,,,,,I did manage to get the long bolt out eventually....lots of banging wd40 and a very long bar and it worked loose,,,,I must admit I nearly gave up,,I did a video of it and put it on you tube under my name
Old Jul 7, 2014 | 10:25 AM
I also did a small video on you tube of me pressing in the new upper wish bone bushes,,,,,,was very easy
dsnyder586
Dec 29, 2024 07:39 PM
KarimPA
Sep 12, 2015 08:15 AM
philwarner
Sep 6, 2015 11:10 PM
arnoldmilk
Sep 3, 2015 07:42 PM
Dallas XK8
Sep 3, 2015 12:17 PM
