1999 XKR won't freewheel when gliding
Old Sep 18, 2021 | 11:27 AM
Nitch's Avatar
Default 1999 XKR won't freewheel when coasting
Hi all,
I hope I'm using the right terms here. My 1999 XKR had an MB 722.6 gear, and when I leave the pedal, seems to be stay at appropriate RPM for the speed, rather than going to idle.
When I switch to neutral while coasting it'll go to idle RPM and if I switch back to D, I can feel a kick.
Is this a normal behaviour? On other automatic cars I drive it was never like this.
Only had the car for 4 months, so don't know what to expect.
Thanks!
Old Sep 18, 2021 | 11:45 AM
drmike's Avatar
Foot off gas and surely RPM gently slow as the car gently slows? You have me worried now but I'm sure this is what every automatic I've had would do. Personally I would never go into N while moving, that just seems wrong. I believe there was an old Rover auto that basically disengaged drive on the over run but I don't think anyone felt it was a good thing.
Old Sep 18, 2021 | 03:00 PM
motorcarman's Avatar
Putting the gearbox in Neutral while driving (especially downhill) is called 'Mexican Overdrive' here in Texas.
https://en.wiktionary.org/wiki/Mexican_overdrive
Old Sep 18, 2021 | 04:38 PM
drmike's Avatar
It's not a common practice in the UK and I had a very worrying trip as a passenger with a business colleague who did it on each down gradient. He said it saved fuel but in his diesel the engine uses more idling (in neutral) than it does on the over run when essentially to fuel is shut off. Gave me the shivers.
Old Sep 18, 2021 | 05:42 PM
Must be a second cousin of the Italian Tune-up.
Old Sep 19, 2021 | 01:33 AM
drmike's Avatar
Old Sep 20, 2021 | 07:32 AM
Nitch's Avatar
Just so we're clear, I don't do 'Mexican Overdrive' regularly, or ever, was just trying this once as I wasn't sure about the behaviour of the transmission.
Either way, the RPM does go down with speed, just seems a little high to me, but maybe that's because my other car has a modern 8 gears transmission, so smoother and keeps the RPM lower when coasting.
Many thanks.
Old Sep 20, 2021 | 08:06 AM
xalty's Avatar
it has lockup in every gear
Old Sep 20, 2021 | 08:17 AM
Try with and without SPORT MODE to see if the RPM is more noticeable in either?
There are TWO reverse speeds with the W5A580 gearbox so try it backwards?
JDog
Oct 4, 2021 12:43 PM
HaydenS
Aug 31, 2017 11:11 AM
powerhouse
May 24, 2014 04:57 AM
vettegood
Aug 29, 2012 04:16 PM
hlgeorge
Jul 28, 2009 03:08 PM
