2000 xk8 top issues
Old Oct 18, 2019 | 09:58 AM
John0626's Avatar
Default 2000 xk8 top issues
I have a 2000 jaguar xk8 the rear windows go up and down but the top will not unlatch to go down. I do not hear the pump turn on in the back after windows go down. Any and all help is appreciated. I do not know much about convertiable tops. But i do know a few years ago the lines were replaced and it worked fine till a few weeks ago and i cannot figure this out.
Old Oct 18, 2019 | 10:03 AM
Dennis07's Avatar
John,
I would first check to fuse protecting the pump motor. If it's blown, and blows again when replaced, don't panic; there is usually a cheap fix for this. See motor repair in my sig. line below.
Old Oct 18, 2019 | 12:07 PM
DavidYau's Avatar
Default 40A fuse or plastic wire connectors gone bad
John,
+1 to Dennis07. The hydraulic pump should be running once the quarter windows are down. Both the hood latch, above the windscreen, and the cylinder rams are hydraulic driven. So the 40A fuse in the trunk fusebox is a good place to start. As Dennis says it’s not a difficult problem to fix.
If it’s not the fuse, there are a number of wires to the pump. The big black/white one is the power connection. Should be secured or can work loose. Really easy to access to check. You know where it is? Pic below.
The blue/orange connectors on top of the pump are really brittle now with age and also break. Worth checking too.
It’s rare for hydraulic pumps to break 100percent. Normally it’s a wiring control problem.
Old Oct 18, 2019 | 12:12 PM
John0626's Avatar
Originally Posted by DavidYau
John,
thank you dennis and david i will check those out after work today and will give an update after i check it out.
Old Oct 20, 2019 | 05:15 PM
John0626's Avatar
My fuse box is not labeled so i could not figure out what fuse would be for the motor
Old Oct 20, 2019 | 05:18 PM
Johnken's Avatar
John, are there any other 40amp fuses in there?
John
Old Oct 20, 2019 | 05:20 PM
Johnken's Avatar
Just looked, there are not. Its the only 40 ampfuse in there.
John
Old Oct 20, 2019 | 05:33 PM
John0626's Avatar
I only see one 40 maybe im overlooking ??
Old Oct 20, 2019 | 07:07 PM
Johnken's Avatar
Hi john,that's what I meant. The 40 amp fuse is for the convertible motion.
John
Old Oct 20, 2019 | 07:12 PM
John0626's Avatar
That 40 fuse is still good. And ive checked all the wires and connections for the on and around the pump all seem like they are connected good and none are loose in the connector. So what would my next step be?
Old Oct 20, 2019 | 08:45 PM
Gus's Avatar
Gus
Check the top down relay.
Link. http://www.jagrepair.com/HydSystemEvaluationXK8XKR.htm
This might help
Link.
http://www.jagrepair.com/images/Electrical/FuseRelayandRoadsideInfo/RoadsideFuseLocations.pdf
Gus
www.jagrepair.com
Old Oct 21, 2019 | 12:06 AM
DavidYau's Avatar
Default Check Relays next
+1 to Gus.
Pic of the relays below.
Old Nov 1, 2019 | 03:20 PM
John0626's Avatar
I checked the relays they are all good. So relays and fuse are good so what would my next step be to figure this out?
+1 to Gus.
Old Nov 1, 2019 | 04:11 PM
Dennis07's Avatar
John,
At this point I would test to see if the pump motor is alive.
Open the 2-wire connector leading to the pump ... the one with two thick wires, one black and one white. You want to apply battery voltage directly to the motor, just for an instant. Using test leads, connect the black wire side of the connector to chassis or battery ground, and then strike a test lead connected to the white wire side against the battery + terminal. If the pump is alive, you'll hear it react. Reverse polarity and try the test again if it works the first time (the pump has to work with both polarities).
Armor6
Jun 4, 2017 08:44 PM
Dennis Jolicoeur
Aug 16, 2016 03:14 PM
Autobahn kid
May 2, 2015 09:30 PM
fshine1
Oct 6, 2012 08:01 PM
Gatorjt
Sep 26, 2012 04:38 AM
