2001 XK8 how to drain the fuel tank
Old Oct 12, 2014 | 08:38 PM
noterman's Avatar
Default 2001 XK8 how to drain the fuel tank
I have a 2001 XK8 that has been sitting for awhile. I would like to drain the fuel tank. Syphon does not seem to work very well. Is there a way to pump the fuel out of the tank using the fuel pump?
Old Oct 12, 2014 | 08:43 PM
Gus's Avatar
Gus
Start the engine and let it run. Why do you want to drain it?
Old Oct 12, 2014 | 10:00 PM
millenia man's Avatar
Default Use a little ari pressure
Put your siphon hose in and place a rag around the hose sealing the filler hole. Poke your air nozzle in through the rag and blow a little air in. It will start siphoning asap!
Old Oct 13, 2014 | 05:44 AM
noterman's Avatar
The reason I want to drain the tank is because the car has been sitting for two years after an engine failure. I do not want to run the new engine with the old gas.
Old Oct 13, 2014 | 09:35 PM
motorcarman's Avatar
You can disconnect the fuel rail supply hose in the engine compartment and get a hose to a large container.
Then jump the relay socket (30/87 or 3 and 5) terminals with a short length of wire to run the fuel pump without the engine running.
The relay is in the boot fuse/relay box behind the battery.
The relay position is..X
OOO
..X
..O
..O
..O
bob gauff
Old Aug 3, 2025 | 09:46 PM
stevepaa's Avatar
I believe the fuel rail supply is under the fuel rail shown here. I think this is the return line and I can disconnect it and connect a rubber hose to the brown tubing to drain the tank using the fuel pump. And no need to plug the female receiver on the fuel return line.
Is that correct?
Old Aug 4, 2025 | 09:53 AM
pcolapacker's Avatar
OOO
..X
..O
..O
..O
bob gauff
Getting wire in plugs difficult so i broke open an extra relay.
Old Aug 4, 2025 | 12:56 PM
stevepaa's Avatar
Do you have a pic of how you added tubing?
Old Aug 4, 2025 | 02:00 PM
Y2KJag's Avatar
I disconnected the fuel filter and pumped it from the rearmost pipe.
Old Aug 9, 2025 | 08:36 PM
stevepaa's Avatar
I pulled the return line from connect and attached a rubber hose then used a switch connected to relay contacts. Just over 9 minutes for 5 gallons​​​​​​​
worzella
Feb 11, 2025 07:16 AM
2jags1993
XJ40 ( XJ81 )
Sep 3, 2019 11:36 PM
wjd03
Nov 30, 2016 07:57 AM
GSHastings
Jul 30, 2014 10:25 PM
porschegonzo
Jun 3, 2008 11:15 AM
