2003 instrument cluster
Old Apr 1, 2026 | 10:57 AM
brinny's Avatar
Default 2003 instrument cluster
Hi all,
I suspect i may have a problem with my instrument cluster. Is there any companies in the uk that can test or repair these that anyone can recomend please.
many thanks in advance.
Old Apr 1, 2026 | 11:41 AM
bladerunner919's Avatar
What's the problem?
Old Apr 1, 2026 | 12:36 PM
brinny's Avatar
Constant abs light cruise unavailable dsc unavailable and speedo works intermitantly. Ive replaced the brake switch and cleaned the rear sensors and rings a couple of times. I had the clocks out to clean the connections and noticed some suspicious looking soldering near the ribbons. I just thought it might be worth having them tested to rule the gauges out. Im not good with electrical stuff. Its a 2003 xkr.
Old Apr 1, 2026 | 02:00 PM
motorcarman's Avatar
The speed input is from the ABS module so I would suspect the CANBUS losing the signal.
Old Apr 1, 2026 | 02:08 PM
brinny's Avatar
Thanks for that. Makes sense. How to i resolve it.? Is it a bad earth somewhere do you think? Any suggestions gratefully accepted.!
Old Apr 1, 2026 | 02:56 PM
brinny's Avatar
Will test the high and low tom and report back.
Old Apr 1, 2026 | 03:27 PM
The ABS light is ON so there are DTCs stored that will tell you where to start.
A simple thing like a wheel speed link harness will cause all sorts of issues.
Old Apr 1, 2026 | 09:01 PM
brinny's Avatar
Yes, it keeps throwing right rear wheel speed sensor. Ive cleaned it twice and the reluctor ring. Tested sensor and wires, all seems good. This is why im now looking at the cluster and other things. Unless im missing something with the sensor?
Old Apr 2, 2026 | 03:29 AM
dibbit's Avatar
Check the live data using an OBD dongle and the Torque app to see what speed the car thinks it's doing. You can then immediately rule the instrument cluster in or out.
Old Apr 2, 2026 | 05:43 AM
brinny's Avatar
Ok thanks for that advice. I will add it to the list. I have a replacement wheel sensor harness on the way and will also try that. It keeps throwing a code for right rear wheel sensor so ill have a go round that though im sure the rear sensors tested fine.
Old Apr 2, 2026 | 08:47 AM
Warmuthb's Avatar
If a high mileage car, you may also want to check for slop in the rear wheel/hub bearing(s).
Brian W.
Old Apr 2, 2026 | 12:18 PM
brinny's Avatar
Brian W.
Good shout Brian i will add that to my list. Thanks a lot.
Old Apr 4, 2026 | 04:12 AM
brinny's Avatar
Hi, i have the car up on axle stands and ran it yesterday. I got a speed reading on the live data that matched the speedo. This was only a short test due to safety. When driving the car the speedo will just stop registering then re start working again when the car is re started. All other instrustments work fine. I have swapped the rear sensors around and cleared the codes. I still have cruise unavailable showing but the abs is off for now. I have ordered 2 new sensors and a replacement right rear link cable. Any thoughts folks?
Old Apr 5, 2026 | 03:12 AM
dibbit's Avatar
You need to test it on the road and see if the live speed data also stops when the speedo stops.
Old Apr 5, 2026 | 05:14 AM
brinny's Avatar
Thankyou. I will do that over the next 2-3 weeks with the new parts fitted and report back. Appreciate the help.
car5car
Oct 16, 2023 11:42 AM
pcolapacker
Jul 19, 2023 11:34 AM
kreyszig
Jan 12, 2023 09:10 AM
Gophat
Feb 28, 2022 12:35 AM
warrjon
Nov 25, 2017 03:09 AM
