2005xk8 crank no start
Old Jan 27, 2025 | 11:20 AM
David Wichmann's Avatar
Default 2005xk8 crank no start
My cross pipe had a hole in it so I replaced that while I was doing that I replaced the plastic fend water pump. There was no issue with it. All the fence were intact. Shut it down normally went to start it and I got a crank no start all fuses Battery was showing 12.3 relatively new battery Attached are some codes
please if anyone can help that would be much appreciated.
these are the error codes that came up for my 2005 XK84.2
Old Jan 27, 2025 | 11:41 AM
kstevusa's Avatar
Perhaps a better description of what the cross pipe is and the plastic water pump along with the fence. These are not terms I relate to a 4.2L engine. Water pump is aluminum, cross pipe could be water hose or some exhaust pipe. Fence usually is a lawn fixture.
12.3V battery points to a very low battery or defective one. Please explain your terms a bit more clearly.f
Old Jan 27, 2025 | 12:51 PM
Default Crosspipe
Sorry Its the coolant cross pipe it’s directly over top of the water pump and it goes from one side of the motor To the other, was leaking coolant it had a crack
Old Jan 27, 2025 | 12:53 PM
Default Crank sensor?
One mechanic told me it could be my crank sensor said that the cross pipe and the water pumper directly over top of that, and if it was dripping, it could’ve short-circuit it
Old Jan 27, 2025 | 01:55 PM
kstevusa's Avatar
Thanks, the water outlet and thermostat housing is directly over the aluminum water pump. The Crank Sensor is at rear under the junction of engine and transmission. With so many codes, sounds like the Battery has possibly failed or poor connections on the terminals because of corrosion. Suggest you have the battery load tested. 12.5v or better is OK.
Old Jan 27, 2025 | 02:03 PM
Default Battey
Thanks Thats definitely where I will start. It was just odd because I didn’t do anything different besides change the cross pipe and the water pump and for that to happen just didn’t make sense but I’ll definitely start with a new battery
Old Jan 28, 2025 | 03:40 PM
michaelh's Avatar
Many of those codes could be historic or spurious with the low battery voltage. Now you have a record, erase them if you can and see which reoccur after the battery swop.
The 4.2L should still start if the crank sensor goes out.
Has the car stood for some time, or was it just down for the maintenance?
Old Jan 29, 2025 | 08:14 AM
Default Crank no start
It was just down for maintenance. I turned it off. It was running fine just leaking and then I got a crank no start. Thank you for your reply.
David Wichmann
Jan 27, 2025 11:15 AM
David Wichmann
Dec 9, 2024 03:20 PM
PitchJaguar
May 15, 2023 03:34 AM
Tony_Likes_Going_Fast_XJ8
Dec 3, 2022 04:12 PM
diamondtrev
23
Aug 30, 2022 11:15 AM
