4.2L AJ33S Engine
Old Sep 24, 2015 | 06:03 PM
dieseldoc's Avatar
Default 4.2L AJ33S Engine
Hi I have a couple of questions about an engine in a 2003 XKR, that I am hoping someone can clarify for me. What is the difference between the AJ33 and the AJ33S? Is there a physical difference, (bigger crank journals, bigger block webbing, etc.) what I am getting at is would an AJ33 long block work in place of an AJ33S long block. Is the difference just that one is supercharged or does the supercharged engine have a stronger block? Thanks for any info you can share on this.
Old Sep 24, 2015 | 09:39 PM
ccfulton's Avatar
Compression ratio is lower the n the S/C version, that's a big difference. There are some other more subtle things like the oil sprayers to cool the bottom of the pistons, or the VVT that the N/A engine has that the S/C doesn't.
The long (or short) block are not interchangeable if you are thinking of an engine swap.
Old Sep 25, 2015 | 02:25 AM
JagV8's Avatar
VVT was added later to SC. Maybe that made it AJ34?
Old Sep 25, 2015 | 05:26 AM
dieseldoc's Avatar
Thank you for the information, makes sense.
Old Sep 25, 2015 | 06:48 AM
XJR-99's Avatar
Different cam profiles.
Old Sep 25, 2015 | 06:49 AM
XJR-99's Avatar
Different cam profiles and fuel injectors.
Old Sep 25, 2015 | 07:20 AM
dieseldoc's Avatar
Could an 2003 XJR motor be used for a swap into a 2003 XKR?
Old Sep 25, 2015 | 09:41 AM
ccfulton's Avatar
The 2003 XJR should be a 4.0L so you would need a 2004+ XJR as a donor to get a 4.2L. And you would have to use the intake from the XKR but otherwise it should transfer from a 4.2L XJR.
Old Sep 25, 2015 | 01:24 PM
dieseldoc's Avatar
Thanks guys you have been very helpful.
Old Sep 28, 2015 | 01:17 PM
Autobahn kid's Avatar
Keep in mind that the XJR and XKR with the AJ27$.0L engines had the oil filter in a different position.
I do not know if the same is true for the 4.2L engines but you may want to look into it.
D.K
Dec 10, 2023 02:05 AM
cissdm
May 3, 2016 06:02 AM
OkieTim
Sep 8, 2015 04:48 PM
jimbo1948
Sep 7, 2015 03:14 AM
OkieTim
Sep 2, 2015 12:48 PM
