5 beeps coming from the dash area
Old Apr 12, 2026 | 07:37 PM
Pantera928's Avatar
Default 5 beeps coming from the dash area
Whenever this 2003 XKR is started, after a few moments there will be a series of 5 beeps emitted for 3-5 times. This will stop then and after a drive of say 30 minutes, this will repeat.
No lights or codes that I can find.
Any ideas?
Old Apr 12, 2026 | 08:30 PM
motorcarman's Avatar
Probably the CLIMATE CONTROL DISPLAY UNIT.
It should have the message ER and a numerical DTC.
Old Apr 13, 2026 | 01:23 AM
Pistnbroke's Avatar
Its a code telling you what the fault is ...Have had it but cannot for the life of me remember what the fault was .I know a man who will ......Michaelh
Old Apr 13, 2026 | 05:19 AM
michaelh's Avatar
Thanks, and you give me far more credit than I deserve.
The attached shows how to interrogate climate control and what most of the codes mean (except the dreaded '17')
Old Apr 13, 2026 | 08:50 AM
Pantera928's Avatar
Thanks @michaelh
I haven't done that check in years and forgot all about it. Not sure if that is the cause of the beeps but I found 4 codes stored. Cant recall if there is a way to manually clear them though and one code has be baffled.
Got codes 11, 14, 23 and 44.
No idea what the 44 means. Any idea?
FYI, the HVAC system seems to work perfectly
Old Apr 13, 2026 | 10:38 AM
michaelh's Avatar
It's in the attachment - B1262 DTC:
44 Defrost vent motor fault Harness / connector fault Servo motor seized or sticking Flap seized
or sticking Refer to PDU
Old Apr 13, 2026 | 12:41 PM
Pantera928's Avatar
FYI, not a pep of a beep since I read the codes but havent used the HVAC system since.
THanks for the info on code 44.
Any way to clear old codes or do they clear automatically once the repairs have been done?
Old Apr 14, 2026 | 01:11 AM
Pistnbroke's Avatar
Read what MichealH sent you !
press FACE and HEATED REAR WINDOW buttons together to clear the faults
Old Apr 14, 2026 | 07:07 AM
Pantera928's Avatar
@Pistnbroke So let me get this straight. You are saying i should actually read the directions rather than rely on my bad memory?
Thanks! I needed that
Old Apr 14, 2026 | 08:32 PM
Pantera928's Avatar
Okay, here is the latest. I checked but did not clear the 4 faults yesterday and for the first time ever, I drove the car without hearing those beeps.
Well, today I cleared the 4 faults and started getting beeps again!
I checked for recurring faults and there were none. A big fat "0".
Did this twice and no faults but got the 4 sets of 5 beeps again.
Any more ideas?
I appreciate the help so far.
JaguarDon
May 8, 2023 09:16 AM
N Bath
XJ XJ12 ( X305 )
Apr 15, 2023 04:42 AM
Catalyst
Sep 2, 2022 09:01 AM
brinny
May 3, 2020 02:31 AM
hartene
Aug 9, 2018 12:46 PM
