97 Headlight moisture
Old May 29, 2009 | 07:38 PM
brgjag's Avatar
Default 97 Headlight moisture
My 97 XK8 drivers head light has moisture in it ALL the time. Looks like a damn rain forest in there. Any fix for this short of buying a new unit?
Old May 30, 2009 | 06:47 AM
test point's Avatar
Long time issue.
See the following:
https://www.jaguarforums.com/forum/s...light+moisture
and here
Old May 30, 2009 | 07:16 AM
JoyceandJay's Avatar
I have a 98 and my husband just open them, they are easy to open and let them air out for a while. That seemed to help me for now.
Old May 31, 2009 | 05:34 PM
brgjag's Avatar
WHat do you mean "just opened them up"?
Old Jun 2, 2009 | 05:43 PM
hafferf's Avatar
Cool
Yes...I agree...how do you open these Bads Boyzzz
Fasr Freddie
Old Jun 2, 2009 | 09:01 PM
Gus's Avatar
Gus
It is a customer interest 417-05 for 1997 – 2004 and it addresses the buildup of condensation in the headlamp assembly. They talk about drilling a 9mm hole in the lamp and install a “T” vent pipe.
If I were to do this I would go to Jag and get a copy of the procedure and see if they have the “T” pipe. Looking at where the hole is to be drilled, moisture may accumulate in that area without the fitting…
Good Luck!
Gus
Old Jun 5, 2009 | 08:58 PM
brgjag's Avatar
For nowI am popping off the access cap to let it vent and dry out.
Old Jun 6, 2009 | 03:25 PM
H20boy's Avatar
I simply leave the clear lid partially open...just not snapped down entirely and it vents just enough to prevent condensation.
Old Dec 10, 2014 | 02:55 PM
nobeljdn's Avatar
04 xk8 coupe driver's side headlight out
Got the moisture out. low beam bulb out. Fuse #8 blown. Replaced fuse; light worked, then fuse blew again. Tried the bulb & igniter on pass side & they are ok. Main light housing plug is clean.
Any tips on what's blowing the fuse? Probably a short from the water which was 1/2 inch deep behind the lens before drying.
Also having panel light issues that may or may not be related.
hoodun
Nov 20, 2022 02:35 PM
kingdom worker
Nov 14, 2020 03:47 PM
sdelliott58
Sep 28, 2015 11:21 PM
Fletch44
Sep 28, 2015 02:21 PM
kevinl
Sep 24, 2015 08:25 PM
