97 XK8
Old Aug 10, 2018 | 03:18 PM
psorco's Avatar
Default 97 XK8
Will not rev past 3000RPM. Cleaned throttle body & mass air flow. Replaced camshaft position sensor, crank position sensor, and both knock sensors as well as timing chains, chain tensioners & guides. Any ideas?
Old Aug 10, 2018 | 05:49 PM
Welcome to the forum psorco,
I've moved your question from Jaguar Forums Feedback & Suggestion Centre to XK8/XKR forum. The Feedback & Suggestion Centre is for posts about the forum and not for technical questions. Members here with the same model will be able to help.
Old Aug 10, 2018 | 07:30 PM
RJ237's Avatar
If you mean it won't rev past 3000 in neutral, that is by design.
Old Aug 11, 2018 | 11:32 AM
psorco's Avatar
Thank you RJ237.
Re: 97 XK8 4.0 engine.
Attempted to take it for a run. Very weak performance. Barely made it out of the garage. Any other suggestions?
By the way, failed to mention that all coils & plugs were also replaced.
Old Aug 11, 2018 | 12:31 PM
RJ237's Avatar
Check the throttle cable isn't very slack, but I think you need to read the codes.
Old Aug 12, 2018 | 06:55 AM
psorco's Avatar
Thanks again for your response. Cable is nice & tight. Although camshaft position sensor has been replaced, I am getting a P0340 code which is camshaft position sensor. Is it possible that new sensor is faulty? Engine idles & runs smooth. But, begins to cut out at 3000 RPM. Will faulty sensor limit RPM?
Old Aug 12, 2018 | 04:34 PM
michaelh's Avatar
Perhaps a little more history.
Did you have any issues prior to replacing the tensioners, etc.?
Did you replace the sensors as part of tracking down this issue?
P0340 can be a faulty sensor, but I'd also check the wiring & connectors feeding it for open/short circuit. Try swapping back the original CPS to see if that helps.
If the electronics can't see the cam position I wouldn't expect it to run fully 'on song'
The second time the code is thrown the Check Engine light should appear. I believe (others will chime in here if I'm wrong) that the engine RPM is limited in this event.
Old Aug 12, 2018 | 06:56 PM
jimangle's Avatar
When was the last time the fuel filter was replaced? A clogged filter can definately cause your problem.
Jim
Old Aug 13, 2018 | 10:08 AM
psorco's Avatar
I did have lack of performance issues. Did some research & cleaned throttle body & MAF. Then checked for codes. Got ABS, Tract control, & coil codes. Sent ABS module out for repair & replaced coils & plugs. Then got Cam & Crank position sensor codes. Replaced both. After these repairs vehicle started & ran smoothly until hit 3000 RPM. Checked for codes again & got Knock sensor codes. Researched Knock sensor issues & found that plastic chain tensioners could trigger Knock sensors. Replaced chains, tensioners & guides as well as water pump & plastic thermostat housing. Also replaced Knock sensors. Will replace fuel filter. Many thanks to all for your help. Will keep you posted. Thanks again!
JagMoto
Mar 15, 2014 04:13 PM
noterman
Sep 23, 2013 10:56 PM
XJsc-guy
May 12, 2012 12:50 PM
bigjohnsonjeeps
Mar 15, 2012 08:01 PM
jagxkrtoofast
Nov 19, 2010 09:32 AM
