97 XK8 Ignition coil jack/connector
Old Apr 13, 2016 | 07:00 PM
skubeedoo's Avatar
Default 97 XK8 Ignition coil jack/connector
I've searched but cannot find the part # for the ignition coil jack, mine is cracked and not making a good connection. Any suggestions for a supplier in the US?
Old Apr 14, 2016 | 06:30 AM
RJ237's Avatar
There have been several threads covering this, so try using the search. The two wire plugs are rare. One technique is to slip the connectors on then use RTV to seal them.
Old Apr 14, 2016 | 11:51 AM
Johnken's Avatar
I was able to use wire ties to secure them as another option.
Old Apr 14, 2016 | 03:22 PM
skubeedoo's Avatar
I've decided to solder them. Why not? Solder melts at 370 degrees, and it's much less mess and a sure connection. Use shrink tubing to cover the butt connections and done.
Old Apr 23, 2016 | 09:25 PM
copyman01's Avatar
I found what you need. O'Reilly Auto Parts PT2045, GM 88988587. I didn't use the barrel connectors that came with the packet, instead I soldered the connectors and used heat shrink. I have a 1997 XK8 convertible. Hope this helps.
Old Apr 23, 2016 | 11:19 PM
Johnken's Avatar
copyman01, I looked the part up, but couldn't tell. Have you found a replacement for the broken connectors that plug into the ingition coil?
John
Old Apr 24, 2016 | 11:53 AM
copyman01's Avatar
I had to special order the part from OReilly. Yes, it's the connector that connects the wiring harness the the coils.
Old Apr 24, 2016 | 05:27 PM
Johnken's Avatar
Wow nice job finding this
Thanks for sharing it!
I hope that they put this in the stickies or something.
Old Apr 24, 2016 | 09:56 PM
copyman01's Avatar
Glad to help. If you have any problem let me know. OReilly has a huge distribution center next to my office and I can put you in touch with a employee who can order it for you. I still have the original paperwork so looking up the part shouldn't be a problem.
[/RIGHT]
CoventryFlagship
Apr 20, 2016 05:52 PM
Atco
XJ40 ( XJ81 )
Apr 18, 2016 02:59 PM
sanchez
Apr 17, 2016 07:42 PM
andyw
Apr 15, 2016 09:33 PM
Pierrick584
Apr 14, 2016 03:23 AM
