97 XK8 wire in trunk
Old Jan 20, 2010 | 10:43 PM
scorch1's Avatar
Default 97 XK8 wire in trunk
While cleaning up the trunk (boot) in my recently purchased '97 XK8, I noticed a light gauge wire hanging out of the large bundle that is adjacent to the battery. It is red with green tracer, and is in a cable jacket with another red with green tracer. It has on the end of it what appears to be the remains of a corroded terminal connector. The wire is about 12" long and is not long enough to reach a connector or device in the immediate area that I can see. Maybe someone could look in their trunk and see where this wire goes in their car? I have attached a picture. Thanks.
Old Jan 21, 2010 | 08:41 AM
motorcarman's Avatar
It is probably for the transit battery isolation device. It disconnects the battery for it's trip across the world from the factory. XKs are different because of the way the windows operate (they drop slightly for the door to open) so it provides power to the windows ONLY and no power anywhere else until the ignition key is operated. They are removed by the selling dealer and returned to Jaguar and then the car is fully funtional. The wire harness is disconnected from the device, just dangles near the battery and now has no purpose.
bob gauff
Old Jan 21, 2010 | 11:02 AM
Brutal's Avatar
^^^^unless it gets corroded and completes a connection between the 2 pins. Then the car wont shut off when you take the key out,, used to be a problem alot on s types with water in the trunk.
Old Jan 21, 2010 | 12:25 PM
scorch1's Avatar
Brutal and Motorcarman, thanks for the quick response. I'll terminate this wire properly and put it back in the bundle.
Cheers.
mrplow58
Jan 21, 2024 05:53 AM
mbergen
Oct 23, 2019 10:26 PM
roby
Sep 20, 2015 01:54 PM
DuhCar
Sep 11, 2015 10:58 AM
al_roethlisberger
Sep 9, 2015 09:14 PM
