98 XK8 problems with closing conv top
Old Mar 24, 2013 | 06:59 PM
epp7's Avatar
Default 98 XK8 problems with closing conv top
Have a 98 XK8
Top closed one day yet the rear quarter windows did not close.
Currently shows red alert roof not latched on dash. The switch
on the console to open and close the roof.. when press'd ..you don't
hear any sound of motor or pump.
Have done n ck'd:
1. hyd fluid is sufficient
2. all fuses are good
3. used the manual latch key to make sure it was closed
4. unhooked both terminals on battery to see if reset
5. looked at right ram to see if it was extended to position.
6. Made sure the petcock was closed
7. Unhooked electrical to top of hyd pump and re hooked up.
These are all I've personally done as a trouble shoot.
What have I missed?
Old Mar 24, 2013 | 07:05 PM
WhiteXKR's Avatar
Is the convertible top sitting flush with the header over the windshield? Is it even from end to end?
Old Mar 24, 2013 | 07:12 PM
beg3yrs's Avatar
Could be something wrong with the microswitches in the latch area. These microswitches sense the position of elements of the latch assembly to let the computer know that the top is latched and the rear windows can now go up. There is a single connector up there that routes all the switch signals down to the computer. You'll have to pull the A-pillar covers, the sun visors and the console light assembly before you can get to it. There are a lot of other posts on opening up the latch area. Pretty easy search ...
Old Mar 25, 2013 | 07:45 AM
epp7's Avatar
Yes, the top is sitting flush and closed tightly. Used the manual allen key to make sure it is closed. Yet, signal still on on dash still on. quarters still down, and nothing happens when you engage the open/close switch.
Am thinking about hooking up a switch to the window hook up to get the windows up at least.
Old Mar 25, 2013 | 07:50 AM
Dennis07's Avatar
Sorry if I missed something ...
Is the raise/lower top rocker switch dead in both directinns, making it impossible to lower the top?
If you can lower the top, do that and then try to raise the top again.
Old Mar 25, 2013 | 07:59 AM
steveinfrance's Avatar
Welcome to the Forum.
Please take time to visit
New Member Area - Intro a MUST - Jaguar Forums - Jaguar Enthusiasts Forum
and introduce yourself so we can all say 'Hello'
Check fuse 14 in the boot fuse box which supplies the pump motor.
It does sound like a microswitch in the latch mechanism though.
If the fuse is OK try undoing the petcock, manually unlatching and opening the top a bit (this is tricky and involves pushing on the top lift rams to force them past over-centre) explained in JTIS or some of the top problem posts here.
That may persuade the system to start working again so you can lower then raise the top.
@Dennis - he says he can't hear pump noises when he presses the switch
Old Mar 25, 2013 | 02:51 PM
epp7's Avatar
Yes, switch is dead at this time in both directions.
Was advised earlier this morning to check the relay in the front fuse box with ohm meter to see if bad as well.
Old Mar 25, 2013 | 03:58 PM
WhiteXKR's Avatar
Just for grins, try the door lock switch to operate the top from the outside (hold it hard against the spring pressure).
Also try a hard system reset (Remove the battery negative terminal, touch the terminals together for a few seconds and replace the negative terminal on the battery. Then reset the windows). If that does not work, I agree, try cycling it through manually.
Old Mar 25, 2013 | 04:55 PM
epp7's Avatar
Re: battery
Do you mean touch the loose neg cable to the connected positive terminal for a few seconds then re attach the neg to neg terminal?
Old Mar 25, 2013 | 05:02 PM
WhiteXKR's Avatar
Originally Posted by epp7
Re: battery
Yes
Old Mar 26, 2013 | 03:41 AM
Re: battery
Here you go
https://www.jaguarforums.com/forum/x...connect-74146/
Old Mar 26, 2013 | 11:10 AM
epp7's Avatar
I will work on this this evening. I am going to use a tester on the four relays to see if they are good. Attempt the door key, and will do a hard reset.
toronadomike
Jan 22, 2026 10:13 PM
Sprayall
May 30, 2021 08:13 AM
alpecsa
Sep 7, 2015 11:55 AM
Sprayall
Sep 3, 2015 07:49 PM
MC36
US Lower Atlantic
Sep 1, 2015 07:34 PM
