ABS Codes 97 XK8
Old Apr 11, 2012 | 03:18 PM
RJ237's Avatar
Default ABS Codes 97 XK8
Today I used my AE software for the first time. I have both ABS and Transmission issues so I will start two threads.
ABS Codes:
C1155 Wheel Speed Front Left Input-Circuit Failed
C1233 Left Front Wheel-Speed Signal Missing
C1095 Hydraulic Pump Motor-Circuit Failure
I switched speed sensor with right front and checked connecting wire continuity, but the codes repeated on left front. I am thinking this is ABS Module problem, and I should send it out for repair.
Does anyone have other suggestions?
Old Apr 13, 2012 | 09:44 AM
Spurlee's Avatar
Module Masters > Home
Good guys
Old Apr 13, 2012 | 10:35 AM
Brutal's Avatar
You need to replace the whl spd sensor link lead harness the is tie strapped to the upper a arm. Its a wire and we all know what happens when you repeatadly bend a wire and you also need to send off the moddule for solder repair on the pump motor power/ground on the circuit board
Old Apr 13, 2012 | 03:10 PM
RJ237's Avatar
Thanks Brutal, the module is out for repair. I checked the resistance of all four wheels at the connector to the abs module and they are identical. If the code repeats when I get the module back in I will replace the wire.
toronadomike
Jan 22, 2026 10:13 PM
skyryder
Mar 25, 2016 08:18 PM
picard
Oct 12, 2015 11:56 AM
JeffinSwitz
Sep 16, 2015 01:44 PM
Bowman
Sep 3, 2015 03:17 PM
