ABS light still on after module repair...
Old Apr 25, 2014 | 02:23 PM
seawind's Avatar
Default ABS light still on after module repair...
I followed these directions "http://jagrepair.com/ABSModuleRepairs.htm" to repair the ABS Module. After the repair the Trac not available and ASC not available warnings went out so I fixed something but the ABS light is still on. Does the ABS light have to be cleared or do I have another problem?
I'm assuming I still have a problem... If so, does anybody know of a good affordable ABS tool that I can scan it with? I remember reading a post on here about one that you plug in to your Android phone but I can't find it now.
2000 XKR
--Ryan
Old Apr 25, 2014 | 07:44 PM
Jag#4's Avatar
If I remember correctly when I repaired mine, it took driving a few miles before it went off.
Have you driven it? It will be safe and your brakes will work, just without ABS if it is still faulty.
If that doesn't work, time to search threads for the other issues that would cause this. You will find tons of threads on the subject.
Old Apr 25, 2014 | 07:54 PM
seawind's Avatar
That's great to hear! No I haven't driven it yet. Pouring down rain and tornado warnings today, not a good time to drive a vert. Let's hope it goes off after a few drives...
Old Apr 25, 2014 | 09:59 PM
motorcarman's Avatar
What DTC is logged in the module?????????????
You might be fixing some part that is not broken and ignoring the real problem.
The fault clue will be logged as a C code in the module.
bob gauff
bob gauff
Old Apr 25, 2014 | 10:31 PM
Gus's Avatar
Gus
bob gauff
bob gauff
Old Apr 26, 2014 | 06:30 AM
seawind's Avatar
I wouldn't make that mistake. I had the codes read in the past which pointed to the module. Sure enough when I opened the module the connections were broken. After I repaired the module the ASC/Trac not available messages went away so I definitely fixed something.
My OBDII scanner doesn't read ABS codes so I don't know what the DTC code is. The only place I know that can read them for me is over an hour away and not open until Mon. And that's why I asked if anybody had recommendations for an affordable ABS tool...?
Thanks for the responses!!
Old Apr 26, 2014 | 07:35 AM
Dennis07's Avatar
Ryan,
By ABS light you mean the little yellow icon, not an "ABS not available" message, right?
If so, and you have no " ... not available" messages, I think you're done. The icon should go dark after a little driving. At least that was the pattern when clearing problems on my '01. Good luck.
Old Apr 26, 2014 | 07:50 AM
batroute's Avatar
2000 XKR
--Ryan
Assuming the original fault is now fixed(and there are no other faults) the ABS light will go out when the car is driven and exceeds(from memory) 12mph.
Old Apr 26, 2014 | 08:35 AM
seawind's Avatar
Dennis07: That's correct, just the icon. The not available messages disappeared as soon as I put the repaired module back in.
batroute: Great, sounds like I just need to drive it! Will do soon....
Old May 6, 2014 | 09:16 PM
seawind's Avatar
SOLVED!! Sure enough, I got a little ahead of myself with this thread. I just wanted to let everybody know after I pulled it out of the driveway and got to "12mph?" the ABS light went right off! The good old ABS module solder repair fixed it right up.
Thanks everybody.
Old May 6, 2014 | 09:25 PM
Jag#4's Avatar
Congrats! It always feels great when one of those annoying little lights goes off for good, doesn't it?
Old May 7, 2014 | 07:52 AM
Jon89's Avatar
Good job. This fantastic forum comes to the rescue once again....
H20boy
Dec 24, 2024 03:23 PM
Shawn Svacha
Nov 4, 2019 02:47 PM
02jagstype
Sep 4, 2015 08:20 PM
laserguy
Sep 3, 2015 02:02 PM
innzane
Sep 2, 2015 10:08 AM
