Adamesh exhaust
Old Aug 24, 2020 | 12:46 AM
tifoso's Avatar
Default Adamesh exhaust
I have a NZ new 2003 XKR and have recently been going through abit of a saga to fit a freer flowing exhaust. Started with an exhaust from Moss Motors in the US but they managed to stuff the order up 100% (every part wrong). Have now received a stage 1 and 2 exhaust from adamesh. Very well made, far higher quality than the bits from Moss Motors. Problem is I can't get it to fit. There's all sorts of weird stuff going on. I can get it all lined up but then the over axle section is hitting the back frame and the front "A" cross member. If I try and wriggle it into place better it falls out of the top rubber mount. It's almost as if the NZ spec cars have a slightly different exhaust system but that can't be. Anyway, seriously considering having the car towed to an exhaust specialist and letting them hack around with the pipes to make it all fit. Up on a hoist there will be alot more room than grovelling around under the car on axle stands.
Couple of questions
1. The centre (front) muffler - which way up does it go? Lettering side up or down? I've had to pull this out as I'm also getting an error code on one of the bottom O2 sensors so will need to remove and check them.
2. The two short sections of pipe that go between the centre muffler and the over axle pipes. These are not labelled L or R. Which one is which as they are different? When fitted one way the centre muffler hangs really low and the other way the pipe is pressed up against the underside of the car.
3. Anyone else fitted the adamesh stage 1 and 2 pipes? Any problems? Any hints on how to make it fit?
Mike
Old Aug 24, 2020 | 07:19 AM
PKWise's Avatar
Tifoso,
I have the same model year XKR as yourself and have also successfully fitted the stage #1 & 2# Adamesh system.
1. The large Central Muffler can be fitted either way up because the entry exit pipes are on the center-line and do not have an incline/decline on exit. You should be able to check this on yours whilst it's off the car.
2. See attached image showing the correct short mid-section alignment. From the angle of shot, it appears the pipe bends upwards a little – very subtle though. It's a case of sliding together the joints and rotating it to the best fit.
3. Yes, there is difficulty fitting!! When finished, I found it a slightly different fit on each side and this is evident at the top of the pic which shows the different over-axle exit positions. The right side was about 20mm lower. Although this is absorbed when fitting the sleeve joint of the tailpipe section. There was also difficulty applying exhaust sealant because there isn’t much play in the joints when fully assembled.
Old Aug 26, 2020 | 11:22 PM
labcoatguy's Avatar
One cautionary note about the rear silencer delete (I believe that's what Adamesh calls their stage 1 exhaust) is that it leaves a nasty droning resonance when cruising between about 1500 and 2500 RPM. I've been mixing and matching exhaust pieces and have found that the rear silencers, which are straight-through resonators, do the vast majority of the work when it comes to dampening that drone. You can get around it by avoiding that RPM range via the J-gate or otherwise via careful driving, but it's annoyed me enough that I've ended up reinstalling those rear boxes while deleting the three silencers ahead of it.
Old Aug 27, 2020 | 04:54 PM
hdjag's Avatar
As already mentioned, the stage one adamesh causes a massive drone. It does make the jag sound a bit louder but the drone is really present and irritating. So much that I take my loses and change back to the original ones this winter.
Old Aug 20, 2023 | 06:20 AM
cdma's Avatar
Has anyone only put the Stage 1 in and did you go with the single or double tips? I am really concerned about the drone sound and do not want to put it in if this is an issue. Stage 2 would make it just a little too loud for the neighborhood.
Old Aug 20, 2023 | 12:09 PM
Jag#4's Avatar
See the two messages just before yours. Drone is the word with Adamesh stage 1.
Multiple Adamesh, Mina and DIY rear deletes on YouTube search. Also try the links below. Adamesh is popular in the UK. Mina is the common choice in the US.
Old Aug 21, 2023 | 03:55 AM
PKWise's Avatar
cdma,
You have a Coupe, so check out this thread:-
https://www.jaguarforums.com/forum/x...ge-1-a-269560/
Old Aug 24, 2023 | 08:46 AM
cdma's Avatar
I was looking at Mina but they only have Stage I and not Stage two. I just would like to install stage two and keep the rear mufflers. I guess I could just go to an Exhaust shop and get the same thing. I will get the new tips though
Old Aug 26, 2023 | 10:11 AM
TedV's Avatar
My 2001 XKR was (I thought) way too quiet and I hated the way the exhaust pipes flattened out over the axle. So a a friend of mine put it up on his hoist and we started removing mufflers. First the very rears. Hardly any change. Then off came the over axle pipes and the next pair of mufflers. Fired her up and wow! That’s perfect. We then rebuilt the exhaust from the central muffler back under the axles and I am so pleased with the results. It sounds great and there’s hardly any droning at cruising RPM’s. It was a bit tricky fitting the new pipe hangers but well worth the effort.
Gerald Clark
Jul 13, 2021 11:40 AM
euphonium01
Sep 24, 2018 07:47 AM
srpope80
E type ( XK-E )
Feb 1, 2018 04:18 PM
John Gloyd
Mar 3, 2016 11:42 AM
l17led
Sep 4, 2009 10:35 AM
