antenna
Old Dec 13, 2015 | 11:30 AM
tony bosco's Avatar
Cool antenna
hey forum, I was just looking at all the ways to disconnect the antenna from going up................. I just listen to cd's..... can I avoid all the different ways to rewire an pull fuses etc. and just pull the wire off the antenna in the trunk and be done with it ??????????? ths tony
Old Dec 13, 2015 | 11:38 AM
jimbov8's Avatar
That is what a lot of people have done.
Old Dec 13, 2015 | 11:42 AM
tony bosco's Avatar
Then its gona work for me too......LOL tks
Old Dec 13, 2015 | 11:43 AM
Jandreu's Avatar
It's a PIA to get to. Has a locking tag on the side against the fender.
If you look at the connectors on the side of the amp it's the same type, a little white button to press and it come off.
Old Dec 13, 2015 | 12:12 PM
tony bosco's Avatar
Cool
pain in the but to get to the little white button ( not sure where button is on the plastic connector)... can I disconnect the black antenna wire instead ???
Old Dec 13, 2015 | 12:57 PM
tony bosco's Avatar
Cool
****** got it had to move my hands around a bit but I got it... antenna stays down and didn"t have to go crazy with wiring.... also the fm still works not as good , but it works............. no am though.... can always plug back in if needed...................thanks happy holidays & happy new year.. tony
Old Dec 15, 2015 | 11:53 PM
Burnham's Avatar
Dang, pulling the fuse in the trunk box (#14 if I recall) is awfully simple .
Old Dec 16, 2015 | 10:21 PM
K.Westra's Avatar
A little more work, but more elegant solution is wiring in a switch for it: https://www.jaguarforums.com/forum/x...antenna-24564/
Old Dec 16, 2015 | 11:20 PM
Burnham's Avatar
Certainly the best way to go, and really very simple to do...even I managed it without undue strain .
Zakeye1
Dec 15, 2015 06:45 PM
Valium.Skies
Dec 14, 2015 11:27 PM
Calhale
Dec 14, 2015 03:52 PM
kentmcnorton
Dec 13, 2015 12:46 PM
obwoodie
Dec 12, 2015 10:01 PM
