Backrest questions for a XK8
Old Sep 15, 2014 | 04:36 PM
mbates50's Avatar
Default Backrest questions for a XK8
Every button on my passenger seat works, except for the position to incline/raise the backrest. I can only lower it. It's a fault in the seat module as it would not work on the drivers side either.
Question: if I disconnect the backrest, will I be able to adjust it manually like the good old days?
Old Sep 15, 2014 | 05:00 PM
avern1's Avatar
Not an unusal problem. The module can develop crack in the copper traces. Search for module repair and there are some good how to's and also some links to others who will fix it for you. To be absolutely sure its the module swap with the drivers seat module. if everything works then its the module. If it doesn't work then search for the threads on the potentiometer repair and adjustments.
Old Sep 15, 2014 | 05:05 PM
mbates50's Avatar
Yep, I did that and failed to mention. It didn't work with the swap. Is there anyway to raise the backrest up manually? Swapping the modules is a pain in the ***.
Old Sep 16, 2014 | 10:09 AM
I can't see a way of manually raising the backrest.
The backrest adjustment on the old manual seats was a tooth and ratchet like a handbrake. The electrically adjustable ones are a worm drive.
Old Sep 16, 2014 | 12:49 PM
ccfulton's Avatar
Last I had a seat apart I don't believe there is a simple way to manually turn the adjustment.
You would be able to access it but unhooking the bottom of the squab cover and lifting it up on the back side but the motor seems to have some kind of braking mechanism to hold the position.
Not sure what damage might be done if you tried to force it to turn but I can say that it won't go easily.
The safest way, if you ever plan to fix the seat, would be to swap the modules.
You might also be able to directly apply 12V to move the motor, but there's no guarantee that the motor is meant for direct DC voltage as opposed to being driven by PWM by the module or something like that.
Old Sep 16, 2014 | 04:48 PM
avern1's Avatar
If i understand all that you have written you have the Seat Back reclined and it won't raise. you have swapped modules and it still won't raise. The seat back reclined with the motor so i don't think the motor is burnt. That only leaves the seat switch as the culprit. I think the switch packs are the same for driver and passenger seat.
Old Sep 16, 2014 | 09:16 PM
Gus's Avatar
Gus
Have you looked at the seat selector switch? This is not a switch for an xk8 but may be worth looking into.
Old Sep 17, 2014 | 01:01 PM
mbates50's Avatar
Default Backrest XK8
After swapping the modules, the back rest worked on the drivers side, so it's the module. (a note to those who want to do this, the connectors on the wiring component have a little button that must be pressed to unlock the module from the wiring. It's on the underside of the component.)
I did find, and spoke with, a guy here in San Diego, Darrell ? 858-649-9090, that will fix a broken circuit for $50. (got his name from this forum) if there is physical damage. He does this for a living and is a retired Navy electrician.
Since an electric seat can't be manually adjusted, this is the cheapest option.
Thanks to all who have responded.
99xk8guy
Sep 29, 2025 10:51 PM
99xk8guy
May 28, 2024 09:36 PM
mrplow58
Jan 21, 2024 05:53 AM
roby
Sep 20, 2015 01:54 PM
Wolfy
Sep 10, 2015 09:50 AM
